Custom Cruiser -74 replacing the lamps for the headlights.
Old January 13th, 2013, 08:46 AM
Odmark's Avatar
How the hell do i replace these? I thought it was just regular Halogen 4 lamps but seems like the lamp itself is integrated with the headlight itself. Just a wire behind the lens if you know what i mean, kind of hard to explain.
You are not supposed to replace the whole headlight right? Very grateful for fast answers.
Odmark is offline
Old January 13th, 2013, 09:11 AM
jaunty75's Avatar
Yes you are! Back in those days, the headlight lamp itself was integrated into the lens housing, and you replace the entire unit.
This is what your headlights look like.
You replace the entire thing. It's not like modern headlights on cars today where you just replace the lamp itself.
For your car, you will have to remove the trim around the headlights and then remove the lights themselves. They're usually held in place with three screws around the perimeter of the light. You'll normally unplug the three-prong (low-beam) or two-prong (high-beam) connector on the rear first. The lamp shown in the photo above is two-prong, so it's a high-beam.
Here's a three-prong lamp.
jaunty75 is offline
Old January 13th, 2013, 09:12 AM
Lady72nRob71's Avatar
On these older cars, you DO replace the entire glass assembly. They should still be available at local parts shops or big box stores.
Lady72nRob71 is offline
Old January 13th, 2013, 03:22 PM
Seriously? The one-piece headlight bulb is called a sealed beam. It wasn't until the mid-1980s that the current non-sealed beam headlights were made legal for use in the US.
Boy, do I feel old now...
joe_padavano is offline
Old January 13th, 2013, 08:02 PM
Oldsdruid
rocketraider's Avatar
Odmark is in Sweden. Europe has used composite and separate-bulb lamps for years longer than we have here in North America.
Yeah, at first I thought "he can't be serious" until I looked at his location. Then his question made sense.
I'm not sure he'll even be able to find a sealed beam in Europe.
rocketraider is offline
Old January 14th, 2013, 07:13 AM
DOH!
I missed that completely. Oh well, RockAuto ships to Europe. Also, you can get halogen sealed beam replacement lamps.
Old January 14th, 2013, 07:16 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
I still feel OLD!
droldsmorland is offline
Old January 14th, 2013, 09:14 AM
Oldsdruid
Izzatchoo makin' them old man noises?!
Guy in my office says when he first gets up in the morning and starts moving around it sounds like somebody walking on bubble wrap with all the pops and creaks.
To kinda sorta get back on topic, I needed floodlight bulbs for one of the motion lights at the house. Apparently there is no such thing as a regular old PAR38 floodlamp anymore- they are all either LED ($$$) or halogen(which I think burn too hot). That and all the outdoor rated ones I can find locally are not a true "sealed" beam type- they have separate reflectors and lenses, glued together. I have already had one of those to separate and drop the lens onto the concrete patio, with predictable result.
It's like I've heard said- "Progress was all right once, but it went on too long."
Old January 14th, 2013, 11:09 AM
Sadly, Glenn, that isn't even funny anymore...
Old January 14th, 2013, 12:14 PM
dancutlass's Avatar
If you don't find any sealed beams here, you could convert to seperate-bulb lamps...
Try the headlights of a BMW E3, that's what I used in my 66, don't know if yours are bigger in diameter though Joe??
dancutlass is offline
Old January 14th, 2013, 12:34 PM
Oldsdruid
74 will still have round sealed beams so the BMW light conversion will probably work.
Didn't Hella produce separate-bulb halogen lamps at one time, that were a direct fit replacement for American 5" and 7" sealed beam lamps?
Old January 14th, 2013, 12:48 PM
dancutlass's Avatar
Don't know if they made them especially as a replacement for the American lamps, but the E3 headlights, I have, are made by Hella as well and they fit perfectly, so maybe Hella sold them as a "conversion kit"
Christophe2m6
October 31st, 2014 11:37 AM
Arrowstorm
Vista Cruiser & Wagons
February 13th, 2014 09:16 PM
GOldman
November 26th, 2012 10:44 AM
TripDeuces
August 3rd, 2010 07:20 AM
DuezPaid
November 3rd, 2007 01:21 AM
Quick Reply: Custom Cruiser -74 replacing the lamps for the headlights.
