'83 98 Regency air vent problem
My dad owns a 1983 Regency 98 and there seems to be a slight problem with the air system. A year ago I removed the radio because it was not working right so I figured I'd check for any loose wires before going out to replace it. After I reinstalled it, the vents were not blowing air even with the fan on max, with the exception of the upper dash vents near the windshield and the two vents on the tranny hump. I checked and there are no loose connections with the hoses, but the front dash vents and side vents by the glove compartment will not give even a whisper of air. Any advice?
Air vents
You must have knocked a vacume line off or pinched one ,Ckeck for Vac leaks,Start with engine & trace back ,Ill usaly remove the line going into firewall & blow cigarett smoke through it while sombody watches dash area & moves controls . Finaly smoking cigaretts does have some good points Larry
84oldsDelta88
20
January 12th, 2016 01:36 PM
OLDSmobility
September 17th, 2010 01:24 PM
