Help with info on rocket 88!
Old Aug 1, 2008 | 09:04 AM
NATESBPD's Avatar
What can you tell me about this car from the numbers???
The car is a 1953 oldsmobile Rocket 88
In the car it says "Hydra-matic" and on the column it says "N Dr S Lo R"
The Style number is "53-36690"
The body number is "L59905"
The Acc number is K2-T
Where can i buy parts to restore it....what engine does it have, what transmission? Where can i buy a transmission rebuild kit for it?
I have the VIN, But im not sure if that tells anything specific about the car...
Please give any info,, im really new to this Rocket 88 stuff.
Thanks!!!!!!!
Old Aug 1, 2008 | 10:55 AM
Well, you can try Fusicks or Kanter for parts. I bet you dollars to donuts the only place that will have transmission parts for that car is Fatsco Transmissions. As for the other stuff, I am not sure. It probably has one of the early Olds engines 303 or 324. Then again, someone could have put a Chevy 350 in it too. GOD FORBID!
Old Aug 1, 2008 | 11:15 AM
redoldsman's Avatar
Proud Viet Nam Veteran
The car came from the factory with a 303 which was the last year since they increased the displacement to 324 in 1954. The engines appear identical. I did nit know until a day or two ago after reading one of Norm's post that in 1953, a lot of Oldsmobiles and Cadillacs used dynaflow transmissions from Buick because the hydramatic plant burned in 1953. From the shift pattern you describe, it appears your car at least came with a hydramatic. Fusick's is the best place for Oldsmobile parts and they are good guys. One of the best things you can do is buy you a service manual for this car. You should be able to find one on ebay. It will pay for itself very quickly. Good luck with your car. This is also a great website and in my opinion, the very best for Oldsmobiles.
Old Aug 1, 2008 | 11:21 PM
88 coupe's Avatar
Junior Member
Originally Posted by NATESBPD
........ car is a 1953 oldsmobile Rocket 88 ........
"Rocket" refers to the engine, not the car. I find it redundant, since all Olds engines were called "Rockets".
........ In the car it says "Hydra-matic" and on the column it says "N Dr S Lo R" ........
That would make it a "Dual Range" Hydramatic instead of the Dynaflow I described, in your other thread. Doesn't mean it wasn't changed by the original owner.
........ The Style number is "53-36690" ........
53 = '53 model.
36 = 88 or Super 88
69 = 4 Door Sedan
0 = If there is anything here, it should be "D" "DX" or "DTX".
........ body number is "L59905" ........ ........ The Acc number is K2-T ........
They can be found in a Fisher Body manual, which I don't have.
........ what engine does it have ........
303 cubic inch V8. The 88 came with a 2 barrel and made 150 HP @ 3600 RPM and 280 lbs @ 1800 RPM.
........ what transmission? ........
Assuming it was not changed, a Dual-Range Hydramatic, as stated above.
........ Where can i buy a transmission rebuild kit for it? ........
Any competent transmission repair shop can get what you need.
........ I have the VIN ........
'53 = model year.
8 (might be 7 in '53) = 88
one of 7 or 8 letters that ID the plant where it was assembled. M = Lansing, MI for example.
The rest are the serial numbers that match that individual car.
Norm
Old Aug 1, 2008 | 11:29 PM
NATESBPD's Avatar
Great! Thank you ver much!
Old Aug 2, 2008 | 12:13 AM
88 coupe's Avatar
Junior Member
........ One of the best things you can do is buy you a service manual for this car .........
http://www.faxonautoliterature.com
Great! Thank you very much!
Glad I could help. And, welcome to the site.
Norm
Mak
53
Nov 18, 2011 04:23 PM
1969w3155
Sep 1, 2011 06:06 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
roadster-rob
Mar 9, 2008 10:24 PM
