More throttle = more heat?
Old September 29th, 2011, 07:27 PM
BStone's Avatar
Noticed that the heater fan on my 67 Delta turns faster when I rev the engine or am at highway speed. Is this normal for older cars?
BStone is offline
Old September 29th, 2011, 07:40 PM
1974 DELTA 88
AZ455's Avatar
Most likely just caused by lower alternator output at idle. My Toyota does this.
AZ455 is offline
Old September 30th, 2011, 06:33 AM
It's normal, just as your headlights will dim a bit at idle!
oldcutlass is offline
Old September 30th, 2011, 06:53 AM
Lady72nRob71's Avatar
All cars' alternators put out less power at idle, but do check to make sure the alt is doing is thing - it is easy!
Check your battery voltage with engine idling (700RPM), lights and heater on high. Voltage should be 12.7V or above. Anything lower would indicate a possible problem.
Lady72nRob71 is offline
Old September 30th, 2011, 08:20 AM
BStone's Avatar
Cool thanks
BStone is offline
defiant1
February 4th, 2020 08:53 PM
Dream Whip
August 9th, 2016 02:59 PM
smcurro
Paint
January 29th, 2012 02:31 PM
bjtstarfire
November 13th, 2008 02:04 PM
72GOTTA
March 30th, 2008 08:15 AM
Quick Reply: More throttle = more heat?
