How to affix vent window glass in frame?
Old February 4th, 2017, 06:08 PM
Supernaut72's Avatar
The rear edge of my driver's side vent window jams against the chrome divider pillar whenever I try to close it. At first I thought the frame pivots were tweaked, but on closer investigation it turns out the glass is just loose in the frame, whatever adhesive held it in has dried up and let go, so the glass easily shifts backwards and attempts to pop out of the frame whenever it's opened.
What kind of adhesive would be the best bet to affix the glass back in the frame?
Supernaut72 is offline
Old February 4th, 2017, 07:03 PM
Oldsmaniac's Avatar
The glass was pressed into the frame with a special glass setting tape that is reproed and comes in different thicknesses. You could also just use black rtv silicone to re-fasten the glass to the frame.
Oldsmaniac is offline
Old February 4th, 2017, 07:06 PM
Cool, I figured it was something like tar tape or the like, but I generally don't like messing around with that stuff. I do have a tube of black RTV that sets like glue and grabs really well so I guess I'll bust out the remaining chunks of the old stuff and use that. Thanks!
Old February 4th, 2017, 07:12 PM
Oldsmaniac's Avatar
Ya, remove the glass and all the old tape. WD 40 will soften it into mush. Clean everything good and insert glass into the silicone. Trim off oose when dry. It does a decent job.
Old February 4th, 2017, 07:25 PM
Good info on softening that old stuff up, thanks. It's definitely rock-hard after all these years. Will be nice to not have to roll down the main window and hold the vent glass to get it to shut.
Update, for closure: Got it. Couldn't find my black RTV but I did find some flowable windshield sealer that I needed to use up. Unfortunately it wasn't as thick-bodied but it still worked in conjunction with the original sealing tape (would have been way too loose in the frame without it). The tape itself, on inspection, was actually in one piece and far more pliable than I had thought, just not sticky. Poured the silicone into the channel after cleaning it up, then applied it generously on the edges of the glass and pressed the tape onto the glass. Let it set up a little and then smooshed it into the frame and cleaned up the excess. Now it clears the division post without assistance and doesn't want to budge from the frame.
84oldsDelta88
20
January 12th, 2016 01:36 PM
Xlhowie
July 6th, 2015 11:56 AM
RandyS
March 7th, 2013 01:35 PM
carmax
October 11th, 2011 07:38 PM
Nickthefish
October 16th, 2009 06:15 AM
Quick Reply: How to affix vent window glass in frame?
