1963 Starfire 88 lower control arm bushings
Old September 3rd, 2016, 07:15 AM
Sdm
Sdm's Avatar
Looking for NOS or TRW lower control arm bushings. We are having fitment issues with the bushing that we received from Fusick. Check out the pictures. We have a gap at the ends of the bushing when connected to the cross bar that bolts to the frame. You can see that the overall length is 3/8 to 1/4 to long which is causing slop. Has anyone else had this problem? will NOS parts correct this?
Shawn
Sdm is offline
Old September 3rd, 2016, 05:03 PM
Phantom Phixer
Charlie Jones's Avatar
NAPA has these bushings available under part # NCP 2673217 .
They fit my '63 OK.
Charlie Jones is online now
Old September 4th, 2016, 05:43 PM
Sdm
Sdm's Avatar
Charlie, I checked that part number and it came back as a rear control arm bushing. Where you able to use this part number in the front lower?
Shawn
Sdm is offline
Old September 4th, 2016, 06:55 PM
Phantom Phixer
That's the number I got from NAPA online.
I threw the box away that my bushings came in.
Probably best for you to contact NAPA , tell them what you need and let them find the right number.
Old September 27th, 2016, 11:59 AM
KQQLCAT's Avatar
Try Rock Auto
KQQLCAT is offline
Old November 8th, 2016, 06:33 PM
Sdm
Sdm's Avatar
Is it possible to have early 1964 control arms on a late 1963 from the factory. Car was sold new in summer of 1963. 1963 lower front control bushings do not fit.
Sdm is offline
Old November 8th, 2016, 07:04 PM
chequenman's Avatar
Shawn
When you push the Bushings into the Control Arm they don't bottom out. There was a ridge on the ones I've done and the Ridge stops at the edge of the Control Arm. When you install everything and lower the car on the Ground, bounce the car once or twice and then and only then can you put the Washer on and Bolt and tighten the Bolt to the correct Torque value.
chequenman is offline
Old November 9th, 2016, 05:33 AM
Sdm
Sdm's Avatar
Part number 12235 looks more like what came out of our car. I may just order them just to see. Thanks for the help. My father in law has owned service stations since the mid 50s through early 1990s, he has owned the car since 1988 and serviced it since new. Car only has 45000 miles. Father in law says the Fusick bushings are not right and after playing with it I agree.
Sdm is offline
jetstar88mike
January 11th, 2016 05:53 PM
speedaddict78
August 7th, 2013 03:20 PM
Bee-Oh-Pee
June 4th, 2012 11:12 AM
HouTXCutlass
March 2nd, 2011 06:16 PM
big_wheel1971
January 23rd, 2010 05:34 PM
Quick Reply: 1963 Starfire 88 lower control arm bushings
