1955 Olds rust repair job.
Old December 14th, 2015, 02:27 PM
flatoz's Avatar
My olds was showing signs of rust coming out under the paint. the rear quarters behind the door were not looking good and then a bubble started to come through on the door. I nursed the thing along for another year or two and decided to take some time off in November to try and sort it out.
Problem I have with this car is it is my every day driver. So anything I do that takes more than 2 days must be well planned and have contingencies for stuff ups or unforeseen issues.
I got the paint colour matched prior to pulling it down and also made a template of the body curve to get some steel rolled as a patch panel. Body work is my least desirable car related job. I can do it, but I know I'm not that good at it. Anyway. to get it done in the 10 days I had and to a level I was happy with I knew I'd have to tackle it myself.
Anyway I live in Melbourne on a standard house block and while thats all good and I have shed space, I decided to do this up the farm where space wasn't an issue nor was making noise to 1-2 am. which we did for about 10 days straight. we worked from about 7-8 through to after midnight all nights. but it was worth it in the end.
anyway. photos. everyone loves photos...
Before.
Pull the interior out and start stripping
My father was helping me and we started out with paint stripper. this was abandoned as a joke after it took all morning to get to this stage on a door alone.
So we went for stripper discs on a grinder to start , the body had many layers and it was hard going.
it seems there were some less than desirable fixes on the car, as you expect, however while I knew there was some bad stuff there I found some that was worse than I thought and some that wasn't as bad as I expected.
the pass side was really full of bog and the dog leg nearly non existent. this worried me.
drives side
flatoz is offline
flatoz's Avatar
First cut has to start somewhere...
so may as well make it a big one.
inner sill repair
I didn't take as many photos of the process on the pass side more on the drivers side.
marking out where I was going to cut to.
previous quality repair
flatoz is offline
Old December 14th, 2015, 02:28 PM
flatoz's Avatar
Right about now I was lucky that a mate turned up to have a look, he knew I was going to be up and about doing this and he’s a qualified welder, I was lucky enough that over the next few days he was in and out and helped. He also welded in the patches as he’s much better than I am at this stuff. I was planning on doing it, but was more than happy to leave it to him. He has nearly completed a massive project of rust repair on a ’55 buick so he was more than familiar with this stuff. He kept saying how good mine was, while I kept looking at it thinking I had bitten off more than I can chew.
As we were working together on the pass. Side I didn’t take too many photos of that side. He left late and the next day I started on my own on the drivers side so I took more photos of that.
Roughed in on the pass side. These patch panels went on and off to may times to count.
Starting mocking up on the pass side
The hoist is a huge help with this work. Getting the car to a height that’s easy to work on.
Time to trim the patch panel. I got the sheety place to make a 8x4 patch. I stuffed up on the first one and then redid a template, they put a crease in that one so it had to be redone again. This of course ate into my time as they are a good half an hour away, so backwards and forwards to Bendigo usually meant the morning lost in getting supplies.
Cleco’s were used to hold things in place, they made it easier and also made sure that the panel went back in the same spot everytime.
Neil doing some final welding on the inner repairs.
The drivers side patch tacked in.
flatoz is offline
Old December 14th, 2015, 02:29 PM
flatoz's Avatar
Prep for paint, using a stripper disc on a buff.
Masked and ready.
Sealer on.
Back together and on the road.
So really to anyone looking at the car would think it looks like a pile of crap with dents and rust repairs showing. However I’m happy as what I see I know is good. Previously I was nervous as to what was under the paint. Now I know it’s all good as such. So next phase will be get the dents beat out and then ready for paint. Being a daily driver this might not happen for a while.
I didn’t take photos of it, but Swifty has a body guy come once a week to work on his coupe and he helped out one night and that dog leg on the pass side, he hand made out of the patch I had got rolled. I didn’t even know he had done it but man was it a relief as I wasn’t sure what was going to happen there and it scared me some. But in the end, I met my deadline and got the car back on the road for family service and now I can just work on the small things as I go along and know that the major rust repair is done and now it’s one dent at a time until it’s ready for paint.
flatoz is offline
Old December 14th, 2015, 03:44 PM
Nice work
oldcutlass is offline
Old December 14th, 2015, 05:11 PM
Rocketowner's Avatar
Great job,you should be done with the rust problems,and it will free up a little time for the dents. You saved it from quickly deteriating . The dent will not get any worse like the rust problems would have. I had a coral and white Super 88 2 dr. Holiday back in 1961. Best of luck, Larry
Rocketowner is offline
Old December 14th, 2015, 05:20 PM
nsnarsk65cutlass's Avatar
Yes,nice work.
nsnarsk65cutlass is offline
Old December 14th, 2015, 05:33 PM
therobski's Avatar
Great work, and a on a time line because u need the "buggy" for a driver!!
therobski is offline
Old January 20th, 2017, 06:03 AM
I know it was a big job but at least it won't come back.Congratulations,you will be very proud when someone ask who you hired to do the metal work and you can point to yourself.
I know ,I installed the Aftermarket Air conditioner myself and had to fabricate the brackets,and it makes you proud when someone ask, who installed your AC ,and you can say, I did. Great job, Larry
Old January 20th, 2017, 08:20 AM
m371961's Avatar
I think you and your friends did a wonderful job. A fifties for daily driving is very cool. Drive it with pride. Anybody can hire out the work if they have cash, but to be able to say I did it raises the bar.
m371961 is offline
Old January 27th, 2017, 12:15 AM
SeanMiller063's Avatar
Wow awesome work
SeanMiller063 is offline
bellymae
Body work
May 30th, 2015 08:56 AM
Switch Blade Betties
November 8th, 2013 04:29 PM
rocketscientist
April 29th, 2010 08:13 PM
easytobedead
Paint
April 10th, 2009 06:16 PM
nosrevle
March 18th, 2006 01:24 PM
Quick Reply: 1955 Olds rust repair job.
