ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Chassis, Drivetrain, Brakes, & Related > Drivetrain/Differentials
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Dealer Listings
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old June 29th, 2006, 12:05 PM   #1 (permalink)
TOONLOVESCHERYL
Junior Member
what is easier to powerbrake
I currently have a 1978 Olds Cutlass Supreme with a 455. It currently has 308 gears, but I am considering swapping to a 410. Will it be easier to powerbrake a 410 rear end or a 308 rear end?
TOONLOVESCHERYL is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old June 29th, 2006, 01:35 PM   #2 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
With a 455 on 3.08 gears you shouldn't have to powerbrake anything. My '69 Delta with a 455 and 2.73 gears roasts the tires by just mashing down on the pedal!
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old June 30th, 2006, 04:24 AM   #3 (permalink)
texasred
Tom Servo's Stunt Double
texasred's Avatar
What year is that 455? HP could be as low as 210, depending on the year/lack of mods. That could explain a lot.
C.J.
texasred is offline   Reply With Quote
Old July 22nd, 2006, 01:03 AM   #4 (permalink)
monzaz
power brake
455 should not need any help power braking any gear...period. Gears...
gears are made to move the car quickly and get the car out of the hole off the line. To deliver maximum torque to the ground.
You will do a smokeier burn out with 3.08 gears because they will spin at a high rpm speed than the 4.10 gears through out the shift points.
Think now before going NO NO NO. Which gear gives you higher top speed?....... times up 3.08 will give your car a higher top speed then the 4.10 so if that tire can get your car to a top speed of 140 miles per hour with in a safe rpm range when you do a burn out it is doing that speed if you go through all the gears spinning. 410 may only have a top end of 120 - 125 before the engine has had enough.... That is why. Faster tire speed MORE SMOKE.
The gears are made for the track and lower ET's quicker from point A to point B Period. Hope this helps you abit figure out what you want. If you need more info PLEASE visit us at JDRACE.COM for more helpful answers of differential questions. differential store and discussion forum CHECK IT OUT! Thanks, Jim
monzaz is offline   Reply With Quote
Old November 17th, 2006, 04:20 PM   #5 (permalink)
rockethound
rockethound's Avatar
it also helps having good front brakes to hold the 455.
rockethound is offline   Reply With Quote
Old November 18th, 2006, 03:12 PM   #6 (permalink)
Redog
Alero Chapter Secretary
Redog's Avatar
I can smoke the tires with the 307 and 3.42 gears, but I swapped from 2.73 about 6 months ago.
The 2.73's could smoke them too.
Hold the brake and push the gas, ease up off the brake just a bit and the car will jump a bit and should start smoking them up
__________________
Me
2000 Alero running 14's
2005 Nissan Altima (her's)
1967 Olds 330 motor sitting on a stand
1985 Delta 88 w/1968 350 rocket ( MURDERED )
Redog is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
