63 Dynamic 88 Wheel help
have you checked your local auto parts store. I was able to get mine from there for a 65 olds dynamic 88. other wise check with USA Parts, Fusicks, try YearOne. They deal in mostly cutlass stuff, but I have found that gm pretty much used all the same stuff when it came to mechanics end of things. USA Parts shows they have them, but they are pretty expensive. But most stuff there is over priced. I would check your local parts store first. i would bet they have them or can order them. chris
1959-67 big cars use the same wheel cylinders, both front and rear.
OE part #s:
Front wheel cylinders, group 4.665: LH 5465046, RH 5465047
Rears: group 4.665, LH 5465038, RH 5465039
Whatever crosses to these applications will work on your car.
OE part #s:
My local independent auto parts store (Joe's Auto Parts in Royal Oak, Michigan, which is affiliated with the Auto Value distribution network) are able to get brake cylinders old Oldsmobiles. RockAuto.com lists some of these as well. Most chain stores do not carry old Oldsmobile brake parts.
Check with a local auto parts store or NAPA. Otherwise, you can send your wheel cylinders out to White Post Restoration to have them rebuilt with stainless steel internals (http://www.whitepost.com/). Best of luck.
CRH
Body work
March 4th, 2012 07:56 PM
