Better gears for my 1980 delta 88
swap
The 73-77 are the same width as the 1978-1996...Same mounting points upper and lower and spring perch mounts. The early 1971-1977 full size rears are wider than the the 78-96 b-body... (wagons are an exception on this rule they are wider)
There also will be a rim / wheel bolt pattern difference too from 5 on 4 3/4 73-77 A-body and 5 on 5" full size 1971 -1996 b-body...One exception here is the impala base model will some times have the mid size car 5 on 4 3/4" bolt pattern circle and smaller 7/16 or metric studs.
Jim
Jim
1969camaross350
Oct 1, 2025 03:22 PM
monzaz
Drivetrain/Differentials
Aug 7, 2014 11:12 AM
1973 to 1977 A-bodies, Cutlass,chevelle/malibu, rear-end housings are bolt-in for 1978 and up B/C bodies. Lots out there with posi' & better ratio's. Ken
