Rear ratio?
Old July 29th, 2016, 06:25 PM
CJG
CJG's Avatar
Rear ratio?
ok. Putting a 455 .030 over, J heads with 3 angle valve job and new stainless valves, high comp Pistons, comp 278 cam, hooker comp headers, torker intake with Holley 850 double pumper carb, and a stage 2 built TH350 with a 2800 stall converter. The car will be driven 80% on 2 lane highway about 12 miles each way and the occasional longer road trip of 30-60 miles to a car show and maybe once or twice a year to the 1/8 mike drag strip just for fun. What rear ratio do you think we should go without? It has stock rear as far as I know now, 71 cutlass 10 bolt, maybe .278's? We will be putting a posi unit in it as well.
CJG is offline
Old July 29th, 2016, 06:38 PM
same but different
don71's Avatar
My vote 3.23 might also consider 3.42
don71 is online now
Old July 29th, 2016, 07:12 PM
CJG
CJG's Avatar
I was thinking 3.42 but wasn't sure how much gas mileage may increase with the 3.23. If it's only a mike or two per gallon of stock with 3.42 just for the added fun factor.
CJG is offline
Old July 29th, 2016, 08:43 PM
What rear tires do you have? The tire diameter will have a HUGE impact on overall gear ratio.
Fun71 is offline
Old July 29th, 2016, 09:00 PM
CJG
CJG's Avatar
Honestly I'm not sure....I think 255-70r15 or very similar.
CJG is offline
Old July 29th, 2016, 09:05 PM
CJG
CJG's Avatar
Nope, way off lol. 275-60r15
CJG is offline
Old July 29th, 2016, 09:54 PM
same but different
don71's Avatar
Like Kenneth said, tire sizes are important. Consider your expectations carefully. Mileage is going to fall somewhere in between. Don't let compromises get in the way of enjoying the car..like the price of gas getting in the way of having fun. Just saying...
don71 is online now
Old July 29th, 2016, 11:31 PM
CJG
CJG's Avatar
I'm thinking 3.08 or 3.23 is where we probably need to be.
CJG is offline
Old July 29th, 2016, 11:46 PM
OK, that's a 28" tall tire. Check the web for RPM calculators and see what your engine speed would be with various gear ratios, then select the ratio that you are comfortable with.
My car has 3.23 rear gears and for a long time I had short 245-60-14 tires (~25" tall) I was OK with turning 3200 RPM on the highway. This was an effective 3.73 ratio with 28" tall tires. Some folks are very uncomfortable with that RPM and others are OK with it. It all comes down to your comfort level.
Fun71 is offline
Old July 30th, 2016, 07:18 AM
CJG
CJG's Avatar
Ok will check it out. I would rather be in the neighborhood of 2500-2800 rpm at 60ish mph. Thanks!
CJG is offline
twilightblue28A
Drivetrain/Differentials
April 9th, 2016 07:13 AM
69-Sguy
November 19th, 2007 07:56 AM
Natas
May 22nd, 2007 08:50 AM
American Lead
March 31st, 2007 04:37 AM
benkerr
August 26th, 2006 07:41 PM
Quick Reply: Rear ratio?
