Can anyone identify this diff?
Old May 7th, 2013, 06:26 PM
I'm indecisive. Or am I..
Napoleon Solo's Avatar
I've been told by 3 people now that they've never seen one like this before. One guy even sent a couple of pictures he took to the guys at Brothers and they were baffled too...
It was under my '65 VC.
( happy now Dave?! )
Napoleon Solo is offline
Old May 7th, 2013, 08:32 PM
hurst68olds's Avatar
Hollander shows the application for '65 Vista Cruiser to be the VC & '65 Buick Special Skyview ONLY!! & I know i've never looked under one of those.
#1369825 (is this the casting number on the center section?)
hurst68olds is offline
Old May 7th, 2013, 09:29 PM
I'm going to blast it tomorrow - I'll check. Any reason why this housing would be different? Extra bump stops for excessive travel? I dunno.
Old May 8th, 2013, 04:40 AM
507OLDS's Avatar
Everything looks correct for a 65 vista. BOP 8.2" 10-bolt. I'm sure Brothers would not know since they just sit on your money until they locate the part that you ordered.The way the shock mounts are shaped are just like the later Vista rears.
507OLDS is offline
Old May 8th, 2013, 09:32 AM
stan 65 cutlass's Avatar
i recognize it, its the one that should be going into my car
curious to see what gears are in it? should be an axle code stamp on the top of the pass. side. axle tube. is that the one thats supposed to be a posi napoleon?
stan 65 cutlass is offline
Old May 8th, 2013, 10:11 AM
monzaz's Avatar
65 vista
WOW. Had to be first year as the vibration dampeners and all cast into the rear ...NOW I know where Mustangs got there idea. lol. Jim
monzaz is offline
Old May 8th, 2013, 12:13 PM
Hey Stan,
This is the one. I'll be blasting it this afternoon so all will be revealed.
Expect more pics this evening...
Old May 8th, 2013, 07:42 PM
Differential I.D. numbers
Ok so it's all cleaned up and I have 3 sets of numbers. Have a look at the pics. Can the gear ratio be determined by the casting numbers? Is there any benefit / desireability to this type of differential? If so the next obvious question is value?
I didn't see any numbers on the p.s. axle tube but these numbers were on the housing:
#1369829 (p.s. rear)
342 (p.s. front)
CFD 1 ( d.s. rear)
Thanks.
Old May 9th, 2013, 09:22 PM
Anyone have any more input?
Old May 10th, 2013, 06:31 AM
507OLDS's Avatar
The 342 is the julian date,or the day of the year that it was cast,so it looks like it was cast the 342nd day of 1964,and went into an early 1965 Vista.
The 1369829 is the casting number for the pumpkin.
The ratio code woul be stamped,not cast,and it should be on the passenger side tube.
507OLDS is offline
Old May 10th, 2013, 07:02 AM
Trying to remember member
wmachine's Avatar
And the CFD 1 is just a Central Foundry Division ID and means nothing more.
wmachine is offline
Old May 10th, 2013, 07:34 AM
Thanks guys. I'm going to have really look around for that axle ratio - it's not jumping out at me.
Old May 18th, 2013, 01:00 PM
HonestDave's Avatar
Hey Napoleon,
Just noticed your thread here. Excellent work figuring out the rear end info. Nice to know it's the correct one for the car. Kind of wish I'd bought the whole car off you and tucked it away, but you probably wish you'd had room to keep it yourself. Hope you find someone who needs a nice solid boxed 65 Vista frame before it goes to the crusher, or has that ship sailed?
Chow mein, Brother.
HonestDave is offline
milehigh
April 11th, 2012 12:07 PM
twill
July 17th, 2011 03:53 PM
auto_editor
Wheels and Tires
December 10th, 2010 03:59 PM
bobb
Body work
November 24th, 2010 05:39 AM
V8Hotrod.com
May 24th, 2007 05:59 PM
Quick Reply: Can anyone identify this diff?
