72 Cutalss GM 8.5 (10 bolt) Bolt in Axles Bearings?
Old June 9th, 2013, 07:43 AM
yankees's Avatar
All,
I'm in the midst of swapping to a new gear and posi into my 72 Cutlass GM 8.5 10 bolt, that has bolt is axles. I figured I may as well swap out the 41 year old bearings/seals from my bolt in axles? If I could just get the parts ahead of time, then I can go the 2 miles to the differential shop and have them remove the 41 year old ones and install the new ones. Lastly I could just pull the axles and take them over and have them purchase and install everything.
Also, Does anyone have part numbers for the axle bearings and seals for the 1972 GM 10 bolt 8.5 axles that bolt in?
yankees is offline
Old June 10th, 2013, 01:13 PM
yankees's Avatar
Are these the correct seals and bearings for my application?
Summitracing.com
Seals TMK-712146
Bearings BCA Bearing Axle Shaft Bearings 146-A9
yankees is offline
Old June 11th, 2013, 06:24 AM
507OLDS's Avatar
Yes,the axle bearings are Timken SET9 or also known as A9 by other companies.
The correct seal is 712146.
507OLDS is offline
JCMC64
June 13th, 2014 07:13 PM
yankees
June 13th, 2013 03:16 PM
72442conv
March 19th, 2012 07:14 AM
71403
July 8th, 2011 10:06 PM
oldzy
Drivetrain/Differentials
September 14th, 2010 05:40 AM
Quick Reply: 72 Cutalss GM 8.5 (10 bolt) Bolt in Axles Bearings?
