Changing a tilt column from column shift to floor shift
Old December 30th, 2012, 05:39 AM
Bitburger's Avatar
I have two 69 Cutlass steering columns. one is a tilt with column shift the other is a non tilt with floor shift. Is it possible to swapped parts on these with the end result being the tilt column set up for floor shift ?
Any help would be appreciated
Bitburger is offline
Old December 30th, 2012, 07:25 AM
It all depends on how you would like it to look after your done. If you take the tilt column and remove the shifter handle and lock it in the neutral position. Grind off the hump and fill the hole, smooth out and paint, your done. All the neutral safety, back up and reverse lighting can be controlled by the floor shifter.
oldcutlass is online now
Old December 30th, 2012, 03:20 PM
Sorry, but you cannot swap those parts. The part you need to swap is called the "shift bowl" and it is different between tilt and non-tilt columns. You CAN swap a tilt floor shift bowl to a column shift tilt column and a non-tilt floor shift bowl to a column shift non-tilt column, but you can't mix tilt and non-tilt parts.
joe_padavano is offline
Old December 30th, 2012, 04:49 PM
Bitburger's Avatar
Thanks, Joe. I'm glad I asked before I started ripping stuff apart.
So anyone out there interested in swapping a tilt steering column with column shift for a tilt steering column for floor shift ?
hvysupreme
February 18th, 2017 12:40 PM
Rocketbrian
October 2nd, 2013 10:18 AM
jensenracing77
January 31st, 2012 06:10 AM
gearheads78
August 9th, 2008 07:56 AM
Quick Reply: Changing a tilt column from column shift to floor shift
