EGR-TCV
Old Nov 12, 2007 | 02:18 PM
Mike77's Avatar
EGR-TCV
I am looking for info on the EGR-TCV Exhaust Gas Regulator- Thermal Contol Valve. My EGR is currently installed on a 1977 Oldsmobile 403 Cu. in. It is supposed to control vacuum to the EGR at 76*F. The TCV is missing.
I am trying to figure out were it goes and what it looks like. I do know there are EGR-TVS- Thermal Vacuum Switch (100*F) or an EGR-DTVS- Distributor Thermal Vacuum Switch (120*F). These are water sensing switches located in the water passage. I don't have a port available on my block to install a water sensing switch. The vehicle is 100% original.
This leads me to believe it may sense via air temperature.
Hoping someone might have a description of the the device, or a picture, a part#, or were I could source one.
I have tried many, many on-line sources and the usual GM/Oldsmobile part distributors with no luck. I am sure it is a common part to many GM motors of that era.
Regards,Mike
Old Nov 12, 2007 | 06:22 PM
crazy'boutOlds's Avatar
I have three of them, used, on my shelf. Send me an email address and I'll send some pics your way.
Old Nov 26, 2007 | 04:03 AM
Jim's rare 80's Avatar
Jim's rare 80
Do you have one like this?But with the tabs still on.https://classicoldsmobile.com/forums...1&d=1196078594
Old Nov 26, 2007 | 05:53 AM
Are you asking me, or him?
Old Nov 27, 2007 | 03:29 AM
Jim's rare 80
Sorry, I forgot to specify. I was asking you, Crazy, because you said you had three on a shelf. Mike comes first, of course. It is his thread.
Old Nov 27, 2007 | 04:13 AM
Is that a three port or two?
Old Nov 28, 2007 | 01:21 AM
Jim's rare 80
It did have two.
Old Nov 28, 2007 | 04:19 AM
I'll check tonight after work. I think all mine have three.
Old Nov 28, 2007 | 05:44 PM
Mike77's Avatar
The picture is of a 2 port Thermal Vacuum Switch TVS. I looking for a Thermal Control Valve TCV. Same but different. Actually I don't know what it looks like. Mine is missiing.
Thanks for the info
Old Nov 28, 2007 | 06:28 PM
My manual says it comes from manifold vacuum to the EGR. It's the one that sits on the timing case shelf. I have a couple if you can't find one.
Old Nov 30, 2007 | 04:15 PM
Mike77's Avatar
That's the one I'm looking for. I believe it just senses temperature, called a TCV.
When you say it "sits" on the timing case shelf are you meaning it does not thread into anything? The one in Jim's picture look's like it threads into the manifold or some place.
Thanks for the reply
Old Nov 30, 2007 | 04:20 PM
Correct, it just sits on it. You should have a metal cover that goes over it, as well. I have both pieces if interested, used of course.
Old Nov 30, 2007 | 07:27 PM
Mike77's Avatar
You the MAN!
Yes I would be interested. Both parts. PPM if you would.
thanks!
Old Nov 30, 2007 | 07:34 PM
I'm going to email you some pics, ok?
Old Apr 27, 2024 | 11:20 AM
Brezzy3304's Avatar
Hi can U send me a few pics of it too, would be appreciated
Old Apr 28, 2024 | 01:51 AM
This thread is from 2007. That member last logged into the site in 2020.
Old Apr 30, 2024 | 05:54 AM
Brezzy3304's Avatar
Hi would u happen to still have those pieces, or would U be able to send me a pic of them, would be appreciated
Chumley
Jun 24, 2009 08:40 PM
Chumley
Aug 3, 2008 01:50 PM
SX455
Sep 16, 2007 06:09 PM
81cutlassconvertable
May 26, 2007 05:16 PM
DonFrost
Ninety-Eight
Jun 22, 2006 04:16 PM
