71 hood on a 70 convert?
Old Sep 17, 2007 | 12:27 PM
Unclemustang's Avatar
Hey all,
I have a 70 cutlass convert that has a plain jane hood. I was wondering if the 71 sport hood will fit without changing anything else ( like the grill ).
Also, has anyone tried the reproduction fenders? Do they fit well?
Marc
Old Sep 17, 2007 | 01:04 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Wink
Originally Posted by Unclemustang
Hey all,
Marc
1970 hoods DO NOT interchange with 71-72. The 70 hood is straight across the at the top of the grilles. The 71-72 hoods have cutouts at the leading edge since the grilles are taller and go up into the hood. The core support is similarly different. If you want to run a 71-72 hood, you need to change everthing from the core support forward (grilles, bumper, headlight mounts) to 71-72.
A 70 hood WILL fit on a 69 if you change the latch mechanism.
__________________
Joe Padavano
Use the forum search next time marc I found this post in like 8 seconds. Glad we can be helpful.
-J
Old Sep 17, 2007 | 01:06 PM
aliensatemybuick's Avatar
"me somebody" site member
I cam pretty sure that a 70 Cutlass hood will not work with a 71-72, and vice versa...the 70 hood is relatively flat across whereas the 71-72 hoods flare up slightly on either side of the center tongue. This results in incompatiblity with the grill and front bumper in fit and appearance.
vistacruiser1971
Nov 9, 2013 01:19 PM
fast442
Jan 30, 2012 08:48 PM
georgiaboy697
Jul 2, 2010 09:23 PM
89Oldsmoble
Body work
May 15, 2009 06:44 AM
scubastever
Jun 25, 2008 11:33 AM
