Go Back   ClassicOldsmobile.com > Vehicle Lineup > Cutlass
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 09-05-2007, 06:16 PM   #1 (permalink)
steve-landy
72 cutlass 4 door
column to floor shift conversion
im new to these forums and came on to see if i can get some advice.
i have a 1972 cutlass 4 door with a 350 2bbl and a three speed automatic on the column. i was wondering how difficult it is to convert the column shift to a ratchet style floor shift, also where would i go to get the parts to make the switch. and if i did change out the transmission which one would be the best replacement. thanks for any advice i can get.
steve-landy is offline   Reply With Quote
Old 09-05-2007, 09:38 PM   #2 (permalink)
The_Jeremiah
Senior Member
Smile good idea
actually its not very hard at all. and if your thinking about replacing the transmission i would recommend a turbo hydromatic 350. thats whats in it already. they are great transmissions and can handle a built 350 easily. anyways im doing the same thing to my 69 cutlass 4-door. it really depends on how detailed you want it to look. the easiest way to do it, is get a B and M unimatic shifter. cut a hole in your floor and do all the mounting work. then knock the pin out of the column shifter and pull that shifter lever out and take off the linkage. thats what im doing to mine. but if you want it to look like a factory floor shift car, which the 4-doors didn't come with so you wont fool a pro lol. then you will need to take the steering column out and get a casing that came from a floor shift car, to get rid of the piece that rotates on the column, then you will need to replace the speedometer to get rid of the gear indicator. then get a stock shifter/console which is hard to find, and put that in too. and you dont need to get a unimatic from b and m. you can get w/e you want, just the unimatic model is made to fit just about anything. gm being the biggest. and they are super easy to install. its also cable operated, so just undo your old linkage, hook up the cable, bolt the shifter to your floor and thats basically it. i recommend almost any b and m just because they are easier to install, otherwise hurst has a great selection of shifters also that might fit your fancy better. good luck
The_Jeremiah is offline   Reply With Quote
Old 09-06-2007, 02:07 PM   #3 (permalink)
steve-landy
72 cutlass 4 door
other options
could i use a b&m megashifter to do the job or would that require extra work. and also do the shift improver kits work well. again thanks for any advice you can give me.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Converting '53 Olds 3 speed manual column shift to floor shift? Alocatelli Transmission 3 02-18-2008 12:36 AM
1959 Floor Pans 19594mydad Chassis/Body/Frame 6 07-08-2007 07:42 PM
Question about Floor pans for 88's bmwashington Chassis/Body/Frame 9 04-25-2007 10:21 AM
'63 Starfire/fullsize Olds floor shift linkage (maybe also for '61-4???) Blownolds Parts For Sale 0 02-15-2007 04:52 PM
my floor rebuild.. what ya think? Droptop Chassis/Body/Frame 13 10-09-2006 06:59 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
