New with a 72 cutlass supreme with Q's
Hi all I have been looking for a clean cutlass for awhile and I thing I found one. I will be going to check it out and hopefully buy it this weekend. The guy I'm in contact with is the son of the original owner he Say's but anyway he is not a "car guy". My question is that he sent me some pics of the engine and it is painted blue (looks original to me?) and the guy says it is a 350 so I'm a little confused is it a 455 it also has a tach. Thank you John
Welcome to the site!
455s were originally blue in 72, like yours there. Of course the real way to tell is to get the casting number over the water pump. The engine could have been swapped out, or repainted, or whatever.
If you do get it, prevent future trouble by eliminating the yellow crimp connector on the positive battery wire. It should be soldered and heat-shrinked. Non-factory crimp connections in the engine bay fail very often.
The factory tach could have been had with the 350 or the 455.
Another quick way to tell is to measure the intake manifold 12inches-350 14 inches-455.
Take a magnet and check bottom of fenders and the back rear quarters just to be sure. you can also crawl on the ground and check frame and floor pans.
hope you get it
Larry
hope you get it
Larry
Well, the fact that there is blue paint on the rubber valve cover gaskets and the PCV valve tells me that this motor has seen a "spray can" rebuild. Worse, the air cleaner looks like the ones used on the 307s. Check the casting number on the small ledge above the water pump, next to the oil fill tube.
Olds 350 engines were Gold, not blue. Look just behind the water pump for the casting number the guys are talking about. I checked my car (its a 72 Cutlass S with a 350, and the casting number is 395558 2 If your car has the same casting number, you'll know what it is. If it's something different, post the number. Someone here will know what it is.
BTW, I just noticed, the rad support is a 4 core which is typically HD. This could be a 455 or a highly optioned supreme. Do you have any info about what equipment the car is carrying?
Not to confuse the issue but I'm fairly certain that I've seen factory 350 cars with blue valve covers and block. I also think they were all 1972 models. In fact, I owned one many years ago. Granted, the majority are gold but there must be some difference in the blue 350 blocks. Can anybody confirm this?
Granted, ALL 1972 Olds 350s were factory produced gold. period. What's the difference between gold and blue? Someone with paint to spare. period.
Allan - There is a real good chance that I'm mistaken...it just seems that over the years I've occasionally seen what appeared to be original, non-restored 350 blocks that were blue with blue valve covers...probably just somebody trying to be creative...or my memory fading with age .
Dan, we were originally talking about 72 Olds 350s. However, you raise a good point. I didn't own a 77 or 79, I did own a 78. In 78 the powerplant for the Cutlass was a Chevy 305, not Olds. I don't know about the 350's in the B Bodies. The very well could have produced blue 350's in 77- 81, I would have to look that up. I know that when the 307 went into production for the 98 and Cutlass lines, the engine blocks were black. In fact all of the divisions installed black engines. Depending on which plant they were installed, there were some valve covers that were blue on the black engines. I have heard of this but not seen it.
Well he sent me a picture it really didn't help much. I really hope one of guy's can use computer magic or something to read it. LOL I'm so non computer savvy. Well I can tell one think tho it was rattle caned.... Well the car is still nice I hope it works out. Here's the Vin 3j57k2z108505 if that helps Thanks again
Yes, it was recently rattle canned for sure, note the bypass hose. The K in the vin indicates the car came with a 350 4bbl (std Supreme engine). The casting number is there, but I cannot read it. My good guess it is still a 350, but we won't know for sure, yet.
Car looks very nice regardless. Paint looks swell.
I once saw the below blue 350 in a 1971 Supreme 'vert. The color was way off, and the casting was for a 350. Most likely a bad repaint.
BTW, this car had "Runs great" on the windscreen. After how much work though??? Car was a complete rust bucket.
Second pic is the casting number we need.
OK thanks I guess I was just hoping the guy was not knowledgeable and I was maybe getting 455 without either of us really knowing...... Honestly I'm still very happy with the car if it turns out to be as nice as the picture and him and I have talked about on the phone. Well I will let you guy's know and I will definitely stay part of the this site. Thanks again John
Well, when I zoom in using Firefox, I can read the last number as an 8. That would be consistent with the 350 block casting number of 395558. Better than a 307, anyway.
Also, as I look at the air cleaner again, it is not a 307 air cleaner because the end of the snorkel is flared - 307s have a straight end that accepts the plastic elbow for the fresh air hose. It's not a 72 air cleaner either, however.
Any 350 is better than that!
I see, sometimes I do not read the fine print. And I am trying to run up my posting numbers. I passed on buying one the other day for 199.
Well it didn't work out this weekend had a family emergency. But I will be heading down next weekend. Trust me I cant wait to see it and hopefully finish the purchase. And then I (we) can figure everything out with it. Thanks everyone and I will be back to pick your brain once again. Thanks John
I don't think I saw anybody mention looking at the number on the lower left side of the cylinder head by the spark plug. If it is a correct 1972 350 it should be 7a. It is a nice looking car.
Del70
September 10th, 2014 04:53 AM
ah64pilot
September 19th, 2012 10:55 AM
70olds455
September 11th, 2011 03:52 AM
olds70supreme
August 1st, 2011 05:22 PM
