ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Vehicle Lineup > Cutlass, 442, and Hurst/Olds > Cutlass
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old August 15th, 2006, 10:33 PM   #1 (permalink)
RussTad
Junior Member
engine trouble
Ok so here goes. Right now my check engine light is flashing. and here is how it progressed.
Car is a 3.1 v6 1997 cutlass supreme sl (4 Door)
About 2 months ago I decided (from a friends advice) to cut a hole in my air filter box. I did that and about a month later when I was comming home from a movie. My check engine light comes on and the car start to idle really rough. I got a new air filter box and installed it about 3 weeks ago at most. I tried to reset the computer but it still flashes. (granted my dumbass still has not gone to get a diagnostic check.
So my engine sounds ok... but the exhaust sounds like a putter. so its put put put put put put and when you accelerate it sounds weird also. But the engine compartment sounds fine. oh since it is idling hard the exhaust sometimes rattles too.
If more info is needed orrrrrr I make no sense at all please email me at Rtada@comcast.net for a better description.
OH yeah last thing I just remembered. right around the power steering there is a lot of grime also on the top of the engine compartment.
RussTad is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old August 16th, 2006, 05:52 AM   #2 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
Russ, first let me welcome you to our site!
It sounds like your catyictic converter may be damaged or worn by the description you give. Those things can get old after a time and get clogged up. Does your exhaust smell abnormal or like rotten eggs? On the very earliest cars with cats they had some trouble like that but I don't think the later ones did but there is always a chance that a previous owner had the cat replaced and who knows about the quality of replacement parts people used these days. It was a good idea to replace the air filter box. With todays engines having so many sensors that the computer uses to control them it was probably a good move. About the grime on the engine, that would be normal from the power steering pump. Clean off the engine and monitor it to see where and how quickly it gets dirty again. On a nine year old car I don't think it is abnormal to have dirt from that, some pumps leak more than others and any dust at all becomes dirt as it sticks to the power steering hydraulic fluid. Use an old rag and some cleaner like simple green or orange plus and just spray and clean. I don't like using the products like Gunk engine degreaser because often you end up with a car that won't start afterwards. Not from the product but from washing it off with water. You have to be real careful with that. At any rate, good luck and I hope to have been some help.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old August 16th, 2006, 08:14 AM   #3 (permalink)
RussTad
Junior Member
actually the engine has a little bit of a sweet smell not a sour smell. But I will check into that cat converter.
Old August 17th, 2006, 05:50 AM   #4 (permalink)
Oldsguy
Oldsguy's Avatar
Well, that smell is definitely very close to a rotten egg smell, I am sure you have experienced it before on SOME car in heavy traffic or at a stop light. You would recognize it again if that was it so it must not be your catylictic converter. Isn't there a way to read the number of flashes the diagnostics in the car's computer give out when you short two of the pins on the diagnostic connector? It seems that I remember reading about that? Just bringing that up as an option because it is much cheaper than buying a diagnostic reader.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
Old August 17th, 2006, 01:42 PM   #5 (permalink)
RussTad
Junior Member
i will probalby just have to go to auto zone and let them do it for free.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1957 Olds super 88 4D Parts? Olds57rocketgal Eighty-Eight 7 May 30th, 2007 09:38 AM
Anyone intrested in a 94 Camaro??? $1575.00 tex70 Cars For Sale 1 January 27th, 2007 09:31 PM
crank casting 397363 needed neoinbiz Parts Wanted 3 December 25th, 2006 07:07 PM
another olds guy odin3eye Cutlass 4 March 30th, 2006 10:00 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
