removed old rochester carb and installing edlebrock
Old Jan 29, 2009 | 08:51 PM
GothamCity's Avatar
Guys,
I am in the process of changing my intake and carb. I have installed the edelbrock rpm intake, and removed the old rochester carb.The problem I have is the edelbrock 650 cfm carb looks different from the old carb and has more connections. So does anyone have pics of similar carb on and olds 350. So that I CAN compare what hose goes were?? Thanks in advance
Old Jan 31, 2009 | 03:52 PM
GoodOldsGuy's Avatar
442=A perfect 10
What year is your engine? What type of setup did you have on the car...picture would help us help you.
GOG
Old Feb 4, 2009 | 12:15 PM
RATCHETMASTER's Avatar
"I reckon so!"
Well, in general, you have the vac. advance, the pcv hose, possibly a vacuum to the trans, one to the brake booster, and one to a vacuum ported switch that is temp regulated and feeds vacuum to egr, etc.
So, without knowing your particular setup, I hope this is of some help.
Sampson
Aug 10, 2014 04:46 PM
jRoofgunner
Dec 23, 2013 09:25 PM
dewcrazzy
Jan 9, 2013 12:14 PM
Kidcutty
Jun 17, 2010 07:48 PM
Oldsfan
Dec 29, 2006 05:52 AM
