Help please...When will I get all the bugs out...
Old June 10th, 2012, 06:33 AM
snookys71olds's Avatar
Maybe someone can answer my question again...really thought i would have my Olds ready to drive today, but another problem arises..Seems my fan blades want to hit my fan shroud.. Can any one tell me what the problem may be.. Do I have the wrong shroud or maybe the wrong fan blade..Motor mounts were replaced...Has a 5 blade clutch fan on it..hits on the bottom of the fan shroud..really bad when driving and braking.. Any suggestions?? thanks...Snookys71Olds
snookys71olds is offline
Old June 10th, 2012, 07:12 AM
Well, you got some of them:
  • Wrong shroud
  • Wrong fan
  • Wrong clutch / spacer (if it came with one setup, and you've mixed and matched parts of the other)
  • Bad clutch (wobbly)
  • Bad water pump (wobbly)
  • Something messed up with the motor mounts (mixed and matched?)
  • Something messed up with the trans mount (too high)
  • Fan shroud bottom tabs not pushed fully into their clips in the bottom radiator mount
And I'm sure others can add more .
MDchanic is offline
Old June 10th, 2012, 07:31 AM
  • Wrong shroud
  • Wrong fan
Thanks Eric....ok.. Motor mounts have been replaced...tranny mount replaced...new water pump.... Is it possible you can tell me what type of fan blade I should have on...I have a 71 Olds Cutlass S with A/C..automatic trans with a 350..seems I have much more clearance on the top than on the bottom.. and yes the tabs on the bottom of the shroud have been cut off and does not pull it down all the way... could that be the problem???
Old June 10th, 2012, 07:38 AM
Has anything been done with two front Radiator core support mounts? Possibly shimmed, installed wrong or wrong part?
oldcutlass is online now
Old June 10th, 2012, 07:45 AM
Either the shroud is too high or the fan is too low. Anything that could cause either of those conditions (or both) could have done this.
Not much to do but start ruling things out.
MDchanic is offline
BIGJERR
September 5th, 2012 04:33 PM
oldzy
June 18th, 2011 03:20 AM
Muskrat
Alero
15
January 24th, 2010 08:48 PM
BigBertha442
February 13th, 2008 09:01 AM
Quick Reply: Help please...When will I get all the bugs out...
