Sway bars.....Ideas?
Old Sep 26, 2012 | 03:14 PM
'69CutlassVert''s Avatar
Just mounted moog coils on my 69 cutlass vert a/c car 6313 rear and 5374 front......kyb gas adjust shocks 5504 rear and 4513 on the front. Any suggestions for sway bars?
Old Sep 26, 2012 | 03:53 PM
The 1.25" front bar from the second gen Trans Am is an inexpensive option. I've bought several at swap meets for $25 apiece. Rear is more of a problem. Ideally the A-body cars want a much larger rear bar to counter the inherent understeer, and increasing the front bar makes that worse. The largest factory rear bar is 7/8". If you can find an aftermarket 1" or larger, grab it. I've found several in the 1" to 1.25" range at swap meets.
Old Sep 26, 2012 | 03:59 PM
66luvr's Avatar
You can ge your wants/needs here CHEAP
http://www.muscle-factory.com/shopdi...s+and+bushings
1.25" front and 1" rears, they worked great on the blue car.
Old Sep 26, 2012 | 04:51 PM
Good info Joe. Ill keep my eyes open at Carlisle if I dont find anything clean used Ill take you up on that website Mike. I had done a lot of research before I decided on the coils and shocks and I just wanted something that would take advantage of those in a curve. Hope it hits the mark.
Old Dec 22, 2012 | 11:42 PM
OldSchoolMuscle71's Avatar
will these work on a 71 cutlass?
Old Dec 23, 2012 | 12:36 AM
speedaddict78's Avatar
Certified Car Crazy
Don't mean to hijack, but would the fbody front sway bar also work on my '78?
Old Dec 23, 2012 | 11:38 AM
Yes, any 1964-72 A-body. Personally I'd go with a $25 F-body front bar and pocket the difference, however.
Old Dec 23, 2012 | 11:39 AM
No, the 2nd-gen F-body bar only works on the 64-72 cars (and possibly the 73-77, but I don't know that for sure). You can get a factory 1.25" front bar for the 78-88 A/G body cars. Just use one of those.
Old Dec 23, 2012 | 11:41 AM
brownbomber77's Avatar
The parts place inc. has the fronts listed on Ebay for $89 and I think another $20 for shipping. They're zinc plated instead of gloss black.
Old Dec 23, 2012 | 11:42 AM
There's usually someone with a 2nd gen T/A bar on Ebay, I just picked one up for $40 shipped but I'm sure the way to go is cash at a swap meet.
oldzy
Suspension & Handling
Jan 3, 2011 02:38 PM
1970_442
Jul 9, 2010 07:56 AM
mmurphy77
May 11, 2010 09:32 PM
bullit
Aug 24, 2009 01:53 PM
Topless72
Jan 6, 2009 01:18 PM
