Tamraz Control Arms
Old Sep 12, 2012 | 07:18 AM
442craig's Avatar
Tamraz Control Arms
Hi Guys,
Anyone know anything about these? Seems like a good deal.
http://www.tamrazsparts.com/product_...oducts_id=1592
Thanks,
Craig
Old Sep 12, 2012 | 08:48 AM
Craig,
I saw those a while ago. Looks good. IIRC they also sell the CAs with bushings so it's a straight bolt in with no fuss and bother. 89 for a new CA is pretty fair IMO!
FYI, I've bought from TAMRAZ before and they didn't disappoint. They don't have as large a selection of Olds parts as some other vendors, but that's the way it goes.
Old Sep 12, 2012 | 09:13 AM
442craig's Avatar
I keep hearing "Cheap Chinese Parts" not necessarily these arms, just wondering if these are Chinese and if it matters? I just need one arm and would love to just bolt it in with little fuss. I have the bushings and ball joints so the stripped down arm is the ticket
Old Sep 12, 2012 | 10:00 AM
Tony72Cutlass'S''s Avatar
My entire interior is from Tamraz. Quality is A1 and i keep getting compliments. Not sure about suspension components though.
Old Sep 12, 2012 | 10:14 AM
Creativeindy's Avatar
Arrrggggg
Before I bought my Tubular U/L CA Sets I shopped around to see about repro replacements. I ended up buying a set from PartsPlace. They get them overseas which is the same place Tamraz gets his from. I will say they feel thin, they didn't line up correctly I had to beat one with a rubber mallet and it still would not go in. It was off by over 1.4 inch from slipping in. The lower ball joint was murder getting one pressed in and the other side was sloppy. I know repro's or some are required to change the design and I couldn't for the life of me find out what they changed outside of weight and metal. I just hoped it wasn't in the geometry of things. With that said, after a day of fussing with them and the cost I sent it all back and ordered tubular sets with everything already on it instead. Came out to the same money wise. I wouldn't suggest everyone do this, esp if you show your car stock is key. I just wanted something good on price, sturdy, and this is my driver so IDC if it's stock or not.
If you order them check the metal when you get them. I didn't put a mic on them but you can def feel and tell the thickness difference as well as the weight difference. Just my .02
Old Sep 12, 2012 | 01:42 PM
I'll give you the same advice allan gave me.
Find a set of clean, OEM A-arms, give them a sand and some paint, and be done with it. If you're really ambitious, then change the balljoints and bushings.
Unfortunately, on our cars, nothing fits like OEM.
Old Sep 12, 2012 | 04:27 PM
442craig's Avatar
Thanks guys, it's about what I expected. I'll hunt for a left side LCA OEM! Anyone have one they'd like to part with???
Craig
Old Sep 12, 2012 | 05:02 PM
oldzy's Avatar
http://www.leverfamilysite.com/controlarms.htm
http://www.leverfamilysite.com/A-Bod..._of_lowers.htm
Old Sep 12, 2012 | 05:14 PM
Craig
Give John MacNeel a PM. He goes by 2blu442 on the site and he parts these things faster than Moses did the Red Sea. He's also close to you - Medford Oregon.
https://classicoldsmobile.com/forums...o=newpm&u=2171
Old Sep 12, 2012 | 05:23 PM
Ive got an LCA but it's probably way cheaper for you to get something in the states. Shipping from canada is ridiculous.
Old Sep 12, 2012 | 05:25 PM
Don't get me started.....Just got 3 big orders from the US yesterday.....I think I own 1/2 of the USPS and Canada Border Customs Services by now
Old Sep 12, 2012 | 06:46 PM
442craig's Avatar
Thanks guys,
I emailed Glenn
Old Sep 12, 2012 | 06:58 PM
Arrrggggg
I also have a complete set both sides all off my 70 442 that are mint. So if you strike out give me a holler I may be willing to part with these.
Old Sep 12, 2012 | 09:08 PM
RAMBOW's Avatar
Ben
Glenn Lever is a good guy & does real high quality work. You won't be disapointed.
Old Sep 12, 2012 | 10:00 PM
Hal's Avatar
Hal
Control arms
I ordered some from them and they took over a month to get and then were the wrong ones. Not to happy with them, last thing I'll purchase from them......
Old Sep 13, 2012 | 08:14 AM
Craig, why not rebuild the ones you have? It's not hard nor expensive.
Old Sep 13, 2012 | 08:33 AM
yankees's Avatar
My front CAs were rebuilt with poly bushings, moog BJs, sandblasted, powdercoated for $325. Not all that cheap.
Old Sep 13, 2012 | 10:32 AM
IIRC the reason for the CA was because he has 2 different style units on the car and the goal was to have both the same.
Old Sep 13, 2012 | 10:48 AM
yankees's Avatar
I have a good complete set coming off of my 72 Cutlass (Lower Oval bushings in the rear) on Oct 13th. They'll need new bushings and BJs.
I'm replacing them with a set of rebuilt ones on that I mentioned in an earlier post (all round bushings). You can have them for $50 and I'll include new poly Oval bushings if you want them.
Old Sep 13, 2012 | 04:53 PM
Ah - somewhere I missed that part.
Old Sep 13, 2012 | 06:42 PM
jfb's Avatar
jfb
Cool follow up.
Craig
how about hidden valley autoparts not dvap in arizona or check the post threads for yards in alabama buddy, I have gotten a lot of oem parts from both sources.
Old Sep 14, 2012 | 09:19 AM
Indy_68_S's Avatar
Hi Guys,
Thanks,
Craig
I'd look for good used OEM before I'd go aftermarket. Seems every A/M part I try requires *modification* of either the parts itself or its surrounding parts.
Sniff around your local craigslist & don't forget that the arms are the same for the same years Chevelles/Malibus, Skylarks/GS, Tempest/LeMans/GTO, etc...)
Southern_Hospitality
Aug 9, 2012 04:28 PM
Joffroi
Nov 3, 2010 04:30 AM
olds4life
Sep 10, 2010 11:26 AM
mhood
Aug 9, 2010 07:31 AM
Insom
Body work
Mar 18, 2010 06:07 PM
