Suspension & Handling
1972 Cutlass S Coupe - Front Spring Rate
Jun 29, 2012 | 07:11 AM
yankees
Sep 2011
Does anyone know what the factory front spring rate was for a 1972 Cutlass S Coupe with No AC, Power Steering, 350 2bbl with Auto trans Turbo 350?
yankees
Find More Posts by yankees
Jun 29, 2012 | 08:14 AM
Lady72nRob71
Feb 2008
Plano, TX
My magic decoder ring displayed an LZ code 280lb spring, same per side.
Lady72nRob71
Visit Lady72nRob71's homepage!
Find More Posts by Lady72nRob71
Jun 29, 2012 | 09:22 AM
yankees
Sep 2011
Thanks for the info. I actually have new Moroso 47160's going into the front that are rated at 242lbs.
yankees
Jun 29, 2012 | 09:23 AM
yankees
Sep 2011
The signature pic is with 28" Moroso DS2s and stock springs, which sits an inch or 2 too high.
yankees
Jun 29, 2012 | 10:01 AM
Lady72nRob71
Feb 2008
Plano, TX
280lb was the lowest rate available on the A bodies in 72. 242 is a bit low, so it will ride smooth but can bottom out easily.
Lady72nRob71
Jun 29, 2012 | 10:13 AM
Tony72Cutlass'S'
Jul 2010
Montreal, QC
By the way, are springs symettrical? So, does it mattery which side is on the top and the bottom as long as i line it up with the drain hole?
Tony72Cutlass'S'
Find More Posts by Tony72Cutlass'S'
Jun 29, 2012 | 11:27 AM
Lady72nRob71
Feb 2008
Plano, TX
Quote:
Originally Posted by
Tony72Cutlass'S'
Closed up side is up. Open side is down.
Lady72nRob71
Front spring rate?
bigmac
12:08 PM
Need high load rate on rear coil springs
Bobac455
07:49 AM
How do 455 GA heads rate?
9teen68/442
06:37 AM
Front spring rate
65oldsf85
02:54 PM
WHAT'S THE GOING RATE? (72 hood)
BosMobile
08:48 PM
Tie rod adjusting sleeve??
08:15 AM
