Suspension question
Old Apr 1, 2012 | 09:18 PM
72cutlassolds's Avatar
Suspension question
I was just curious im restoring my front suspension and did the driver side already now im starting the passenger side and noticed alot of black grease on the drop spindle and upper ball joint is that normal was i suppose to have lube the driver side when i did the other side ?
Old Apr 1, 2012 | 09:26 PM
Rickman48's Avatar
NO suspension part is pre-lubed from the factory, and metal-to-metal unlubed parts wear-out fast!
Old Apr 1, 2012 | 09:53 PM
will wheel bearing grease do the trick so should i go grease up the the other side
Old Apr 1, 2012 | 10:07 PM
Rickman48's Avatar
Wheel bearings should be packed correctly, with a seal on the inside!
It's 'tapped on' the rotor or drum!
Old Apr 1, 2012 | 11:15 PM
what kind of lube should use for the drop spindle and ball joints
Old Apr 2, 2012 | 09:10 AM
Rickman48's Avatar
Chassis grease!
Go buy a hand grease gun + grease at a auto parts store!
Fill everything until the rubber bulges.
Old Apr 2, 2012 | 09:38 AM
sammy's Avatar
Sammy70 455 Supreme
I do not know about you guys,but I am thrilled when I see a grease nipple-must be getting older on these cars.My wife's Mazda does not have one-everything is sealed
Old Apr 2, 2012 | 12:09 PM
Lady72nRob71's Avatar
Ball jooints get chassis grease, wheel bearings get high-temp bearing grease.
Lube everything well before driving!
Old Apr 2, 2012 | 12:39 PM
Eddie Hansen's Avatar
ohhhhhhh mannnnnnnn......
Now I know we are getting old, when grease nipples turns us on LOL.....
sorry Sammy it just sounded so funny......
Old Apr 2, 2012 | 02:53 PM
sammy's Avatar
Sammy70 455 Supreme
That's exactly why I put the happy face after "getting older" I felt old typing it......
Old Apr 2, 2012 | 04:29 PM
Bluevista's Avatar
Registered
The proper name is "Zerk fitting".
I don't think my wife has any of those either.
LoganMiller68
Mar 12, 2012 10:44 AM
toymaker199
Jul 15, 2009 11:48 PM
wazoo
Hurst/Olds
Jul 8, 2009 06:43 AM
DAN76
Jun 10, 2009 05:52 AM
JSGD1966
Dec 5, 2007 01:23 PM
