Upper &lower control arm question
Old Mar 23, 2012 | 09:58 PM
72cutlassolds's Avatar
I was wondering how tight should the bolts be on the upper and lower controll arms in my 72 supreme at first they were to tight cause they wouldnt move after i finished so i backed off the screw a lil now the move slighty not alot but they move ?
Old Mar 24, 2012 | 07:52 AM
Lady72nRob71's Avatar
They are supposed to be tight and unlubed. Somewhere around 90ft-lbs for the lowers I think. The uppers are tight as well, over 60lbs - cannot remember the spec off hand.
The twisting motion occures IN THE BUSHINGS. The rubber twists and acts like a bearing.) The arms are not supposed to pivot on the bolts. Doing so will cause damage to the lower frame mounts (the steel cores will grind them away or the bolt holes get wollowed out).
Old Mar 24, 2012 | 12:51 PM
Ok thanks for your help
botz
Jul 4, 2015 07:51 AM
akins2000
Jan 22, 2012 12:39 PM
oldsmbl
Nov 2, 2011 07:11 AM
tiparosa
Feb 26, 2007 10:43 PM
