1972 Olds Cutlass LCA's?
Old Oct 28, 2011 | 10:27 AM
yankees's Avatar
How do I know if I have round or oval LCA bushings on my 1972 Olds Cutlass S Sport Coupe, without having to first remove them?
I want to use Del-Alum bushings, but they only come in a round style for the LCA's. I assume I should just buy a set of 68-72 round bushing LCA's from a chevelle or another A body.
Does anyone have any 68-72 UCA's and LCA's (round bushing) that they want to get rid of?
Old Oct 28, 2011 | 10:39 AM
Tony72Cutlass'S''s Avatar
Rockauto will be your best bet.
And if you mean your lower front suspension A-Arms. Then yes, One is round (front), one is oval (towards the rear), and you cannot just use two round ones...
Old Oct 28, 2011 | 11:30 AM
I have the same car. I'm putting in boxed rear OEM' lower rear CAs so I just looked at them. They're both round.
Old Oct 28, 2011 | 11:41 AM
RetroRanger's Avatar
72 Olds CS
Ive read that cars came w either the round or the oval bushings Ive not read where its definitive as to year or model
I *think* the only way to tell for sure is take it apart
I saw I think parts place or somewhere else sold the oval bushings as a set of two so you could buy the 4 rounds and two ovals to cover all the bases !
Allan manny is asking about the front LCAs
Manny I will give you my old UCA bushings no charge
Old Oct 28, 2011 | 12:03 PM
yankees's Avatar
Front Arm LCA's
Everyone thanks for the replies. I think I'll get an extra set of front LCA's that accept round bushings for the front and back. Now I just need to find a used set. Anyone Anyone Anyone???
Also, I assume I can buy any front, rear suspension and steering part from a 68-72 chevelle that will work on my car???
I just realized that I had a spare set of 69 Camao Front LCA's, but are they the same as the 68-72 front LCA's ?
Old Oct 28, 2011 | 12:06 PM
Ok, now I got it. Manny the LCAs use 2 types of bushings - round and oval. I think the Moog number is 5149 on those. Have a look at this thread. It will show you what you're looking for. https://classicoldsmobile.com/forums...tml#post290179
Old Oct 28, 2011 | 12:09 PM
Manny, the LCAs are pretty much the same for these for a lot of years. Just press out the bushings and replace them. If I can do it, you can too. Why spend money on new LCAs when its just a bushing replacement you need? I could be wrong, but if you want round bushings you might need to change to tubular CAs and I don't know how much modification that would need.
Old Oct 28, 2011 | 12:33 PM
oldzy's Avatar
I had the same dilemma (I had oval ones - I was going to use the GW del-a-lums, but decided to go with ES poly bushings instead)... and since my arms were all pitted anyway, I bought a decent set from G. Lever @ http://www.leverfamilysite.com/controlarms.htm
http://www.leverfamilysite.com/A-Bod..._of_lowers.htm
Old Oct 28, 2011 | 03:47 PM
Well dog my cats! I didn't realize there were 3 different versions of the LCA that look pretty much the same. Good info, thx.
Old Oct 29, 2011 | 09:16 AM
yankees's Avatar
I just realized that I had a spare set of 69 Camaro Front LCA's with Del Alums now, but are they the same as the 68-72 front LCA's ?
I also need to call Global West to determine if the GW bushings that I have will work with the 72 Olds LCA's (At least for the front bushing since it's round).
big_wheel1971
Suspension & Handling
Jun 28, 2011 07:15 PM
oldzy
Jun 19, 2011 07:56 PM
oldzy
Jun 7, 2011 12:11 PM
