Variable vs constant rate springs
Old Dec 26, 2010 | 12:08 PM
jerseyjoe's Avatar
Hi All, I am going to need to replace the rear springs on my 68 cutlass convertible. I'm hoping someone could tell me the pro's and con's of each type of spring and any recommendations. I am looking to improve handling a little while getting the ride height back to normal.
Thanks, Joe
Old Dec 26, 2010 | 11:13 PM
henryk8398's Avatar
Hangin' out...
Hi joe,
This is a good explanation of variable vs. stock springs:
http://www.federalmogul.com/en/After...n/CoilSprings/
Old Dec 27, 2010 | 06:46 AM
Lady72nRob71's Avatar
Variable rate springs will allow for both a comfortable ride as well as keeping the rear more level when loaded down. These would be good if you carry a big family or go cruising with all your buddies in the back.
Simply replacing springs will often help get the ride level restored and reduce bottoming out, as the old ones will be fatigued and sagging.
I have found the new Moog springs to be stiffer than OEM originals. (Like the STD springs being a bit stiffer than the stock STD springs).
It is recommended to find out what your original spring's rates are by consulting the assy manual for your car. The moog spring rates are listed in one of the links below.
Those may help you decide on which to use.
Adding a sway bar and boxed control arms to the rear are recommended for greater stability, also.
https://classicoldsmobile.com/forums...tml#post170009
https://classicoldsmobile.com/forums...ancements.html
Old Dec 27, 2010 | 12:21 PM
jerseyjoe's Avatar
Thanks Rob, Great information! I like the idea of a more comfortable ride. It will mainly be my kids in the back seat if anything. I just don't want the car to lean over going around turns b/c the variable rate spring are too soft.
Joe
Old Dec 27, 2010 | 12:54 PM
Actually the variable rate ones may be the firmest ones. They were for the rear of my '72. 175lbs vs 164lbs for the heavy duty constant rate. Sounds like you really want that sway bar setup. New bushings back there will add more stability, too!
delta_88_germany
Feb 22, 2014 01:48 PM
Clydesdale
Aug 2, 2012 07:24 AM
Texas69
Feb 11, 2012 05:21 AM
senginc
Drivetrain/Differentials
Jan 2, 2012 08:52 AM
Bobac455
Jul 16, 2010 07:49 AM
