i hear a knocking or thumping!!!!!
Old Apr 8, 2010 | 03:56 PM
88 custom's Avatar
Ive been hearing a knock or a loud thumping when i drive i changed both sway bar links that seemed to be ripped to shreds and still i hear noise i have a 1968 delta 88 custom plz can someone help? (Its not the engine).
Old Apr 8, 2010 | 04:08 PM
Erinyes's Avatar
You didn't forget to let your friends out of the trunk the last time you all went to the drive-in, did you?
Old Apr 8, 2010 | 04:27 PM
88 custom's Avatar
Lol very funny!
Old Apr 8, 2010 | 04:42 PM
Erinyes's Avatar
I couldn't resist :-)
Seriously, though, more info would be useful. When does it make noise? Constantly? Only when turning? Does it vary, and if so, does it vary with engine rpm or road speed? More data!
Old Apr 8, 2010 | 06:22 PM
88 custom's Avatar
it doesnt make noise when sitting steal mainly when picking up speed over 15 mph driving straight then it starts to thump i can fill it trew the floor board
Old Apr 8, 2010 | 06:27 PM
Erinyes's Avatar
Check your u-joints, pronto.
Old Apr 8, 2010 | 07:09 PM
88 custom's Avatar
ok thanks man! i hope it isnt bad.
Old Apr 8, 2010 | 08:15 PM
88 custom's Avatar
couid it be the tranny? cause it drives good except for the noise.
Old Apr 8, 2010 | 08:46 PM
yzzerdd's Avatar
Honestly, I'd say it is more than likely not the tranny, but definitely the U-joints. I'd replace the U-joints and such, and see how things go. Inspect the driveshaft for damage as well. When you put the car in gear, does it clunk?
--Ryan
Old Apr 8, 2010 | 08:53 PM
70 cutlass s's Avatar
More detail when does it do it. Turning, giving it gas, or braking it could be several things.
Old Apr 9, 2010 | 12:20 AM
88 custom's Avatar
It starts to make noise when i press on the gas the faster i go the louder it get i can fill it on the floor board..
Old Apr 9, 2010 | 05:15 AM
Lady72nRob71's Avatar
Is it coming from the front or back?
Withthe car parked, grab ahold of the top of each front tire and push and pull it vigorously. If anything seems loose, you are getting close to the problems, either ball joints, wheel bearings or bushings.
There should be a reason your end links were torn to shreds - they usually do not wear that way.
Old Apr 9, 2010 | 07:59 AM
citcapp's Avatar
Check your universal joints at each end of you drive line could be that one or the other is going out. Lots of people forget to grease them. Not a pretty site if the front breaks and you do a drive line stand
Old Apr 9, 2010 | 10:57 AM
yzzerdd's Avatar
Ha, maybe you should check to see if someone attached a big 'ol zip tie to your driveshaft. Its a common prank around here to loop a big zip tie around a driveshaft (FWD or RWD) and then when they drive, the slack of the zip tie thumps on the bottom of their car. Then they think they have this big issue, when it's really only a zip tie.
But seriously, I'd bet on the U-joints. But, to make an even more accurate assesment, we'd need to know exactly where the noise is coming from.
--Ryan
Old Apr 9, 2010 | 11:44 AM
Try looking at your body bushings????
Old Apr 11, 2010 | 11:52 AM
88 custom's Avatar
thanks guys i found the noise it was the rear rt tire the bearings are bad.
Wyze
Sep 28, 2010 06:37 PM
MN71W30
Sep 22, 2010 02:13 PM
Jamesbo
Feb 1, 2010 07:21 PM
texasred
Jan 21, 2009 01:02 PM
GoldOlds
Dec 9, 2007 10:03 AM
