72 cutlass convert. Hotchkis rear bar
Old October 6th, 2016, 10:33 AM
Gary M's Avatar
Anyone know if that rear sway bar would hit a W-27 aluminum diff cover? Searched past posts but did not see one where the sway bar attaches to the axel on each side like the one in the picture would.
Gary M is offline
Old October 6th, 2016, 01:24 PM
72 Olds CS
RetroRanger's Avatar
They offer 2 diff rear bars, the less expensive one attaches like the factory bar the more expensive one is clamped to the axle tube and has links that attach to something I can't recall Atm
RetroRanger is offline
Old October 6th, 2016, 06:00 PM
Gary M's Avatar
For future reference.
Hotchkis rep says the sway bar will not hit the W-27 cover.
Gary M is offline
Old October 7th, 2016, 07:46 AM
oddball's Avatar
I run an axle mounted sway bar from Hellwig. It DOES hit the W27 cover in certain situations. This one might have a bigger deviation in the bar that might clear the cover, but I wouldn't bet on it.
oddball is offline
Old October 7th, 2016, 08:27 AM
Gary M's Avatar
Say it ain't so....
We all know salesmen never lie.
Gary M is offline
Old May 8th, 2017, 07:46 PM
Rodney
cdrod's Avatar
Hellwig bar hits W27 cover
I know this is an old thread but a picture is worth a thousand words. I have the Hellwig sway bar PN55706 on my car. The bar cleared the W27 cover when the suspension was in full droop, but would hit the cover as the suspension compressed as I lowered the car. I had to take off the W27 cover, I'm using a TA support cover now. Here's a pic of my problem.
cdrod is offline
Old May 9th, 2017, 05:38 AM
JohnnyBs68S's Avatar
Wouldn't spacers between the U-bolts and sway bar bushings provide enough clearance to avoid hitting the cover?
JohnnyBs68S is offline
Old May 9th, 2017, 06:02 AM
Rodney
cdrod's Avatar
I thought about spacers too, so I took the cover off and lowered the car to measure the clearance. The Hellwig bar is designed to rotate up behind the differential when the suspension is in compression. I estimated the spacers would need to be 2-3" to provide enough clearance at the cover. I didn't want the bar hanging that low so I put on the TA cover with the bearing cap pre-load bolts. Here's a pic, This pic is with the chassis on the ground and the body off the frame so the suspension is unloaded.
cdrod is offline
oldzy
July 1st, 2012 08:05 PM
oldzy
January 15th, 2012 06:18 PM
oldzy
Suspension & Handling
April 11th, 2011 07:35 AM
oldzy
December 3rd, 2010 08:20 AM
oldzy
November 30th, 2010 11:33 AM
Quick Reply: 72 cutlass convert. Hotchkis rear bar
