Bronze engine paint
Old May 21, 2008 | 05:09 AM
dan1s's Avatar
Bronze engine paint
Who sells the Bronze brush on engine paint?
Thanks, Dan
Old May 21, 2008 | 06:59 AM
Thanks, Dan
Don't know about brush-on, but Fusick has about the best color match in a spray can. Note that this paint is heavy metallic and as such the final color is very dependent on application technique. The normal approach of several thin coats results in a much lighter than stock color. The factory applied one wet coat (they really didn't care about runs) and this technique results in a darker color. Brushing it on will produce something different still.
Old Sep 25, 2008 | 06:49 AM
442scotty's Avatar
DOES ANYONE HAVE A PAINT CODE FOR THE 442 BRONZE PAINT...I CANT SHIP SPRAY CANS OVER THE BORDER AND FUSICK DOESNT SELL QUARTS ANYMORE...HELP!!!!
Old Sep 25, 2008 | 05:32 PM
Bluevista's Avatar
Registered
Bill Hirsch has it.
http://www.hirschauto.com/prodinfo.a...on=OLDZ%20BRZN
Allan
Old Sep 25, 2008 | 05:50 PM
442scotty's Avatar
Originally Posted by amh555
THANKS...HAS ANYONE TRIED IT...COLOR OK?
Old Sep 27, 2008 | 01:53 PM
sculling bob
Guest
Posts: n/a
I have a '67 442 with the original 400 and the remains of the original valve cover sticker. The paint on the motor & valve covers was still good. I peeled off the valve cover sticker to see the how the paint had faded. It was looked to be the same and using this guys info: http://442restoration.homestead.com/restortips.html
I finally found some of the Plasti-Kote color FM8069 he mentioned. It matched perfectly in my vision. It is a lacquer. It is horrible to paint with gobs of metalic in the botom of the spray can and the nozzel plugs constantly. I wanted enamal so I went to a helpful PPG paint shop and they gave me this OMNI number by the quart: OMNI AE OEM Code M5144A, MX701855, UCMCXXA, V FORD (N. AMERICA) MED CHESTNUT POLY
I haven't seen it painted as the motor is not done, so I'll wait and see (less than $30 a quart). Why in the world Olds chose that color for a motor I'll never know. Sure is pretty but what a pain for painting a motor.
Old Sep 27, 2008 | 03:08 PM
442scotty's Avatar
I AM HAVING THE SAME PAINT, OMNI, MIXED FOR ME AND WILL TRY IT OUT MONDAY...WILL LET ALL KNOW AND POST A PICTURE...GONNA TRY IT ON MY OIL PAN... GOING WITH ACRYLIC URETHANE OMNI FOR A BETTER COLOR MATCH
Old Sep 30, 2008 | 10:56 AM
442scotty's Avatar
here is my oil pan using omni acrylic urethane...How does it compare...the color on my screen matches the pan...I like it but is it close to correct?
Old Sep 30, 2008 | 11:14 AM
For brush on bronze engine paint I suggest POR 15. They make an Oldsmobile bronze color. I don't know if it matches the original well but the durability of the paint is superior to anything I have ever seen before. This stuff is great!
Old Sep 30, 2008 | 11:45 AM
442scotty's Avatar
didnt know POR15 does bronze!...The paint I used is the same I used on a 455 olds about 5 years ago in blue...still looks perfect today and has not burned off at all...
Old Sep 30, 2008 | 01:40 PM
Danny Wiseley's Avatar
Originally Posted by 442scotty
Attachment 2751
I like it, too! The color looks really, really close to me!
Old Sep 30, 2008 | 02:14 PM
Lady72nRob71's Avatar
I sure like what I am hearing about the POR15 brush on engine paint!
I have a can of Olds Gold on order for my 72's 350.
Not sure how close it is to original color, but as long as it stays on there (unlike the paint now) I will be happy! (Especially without priming).
I will be doing the paint job this coming spring when the A/C system is pulled for resto...
BTW, that copper color looks almost exactly like my old Ford's exterior paint!
Old Sep 30, 2008 | 04:01 PM
442scotty's Avatar
bet it was a 76 ford (thats what the color is)
its about the only good thing I can say about ford...sucks that I had to resort to that
Old Oct 1, 2008 | 05:30 AM
Actually, it is a '78.
The color is called "medium chestnut metallic". A long word for "copper".
It still holds a shine, so it must be a toxic blend with lead or something... I do have to say it is unique!
kelly bakies
Nov 23, 2014 01:41 PM
gman
Sep 9, 2014 05:38 AM
vistaride
Oct 29, 2012 07:36 PM
vistaride
Oct 23, 2012 05:46 PM
CHRISH8846
Apr 16, 2010 02:33 PM
