How to change mast of power antenna
Old May 4, 2008 | 05:35 PM
dan1s's Avatar
Does any one know how to change out the mast of a 68' rear power am antenna. I just found another setup and just want to change out the mast.
Dan
Old May 5, 2008 | 05:49 AM
Oldsguy's Avatar
Past Administrator
I don't know for sure, I do know that most power antennae operate by winding a nylon filament like fishing line only large gauge around a spindle on a motor. One end it attached to the spindle, the other to the top inside tip of the antenna, if the filament has broken or become un-attached at the top I don't know how to fix that, or to install a new mast.
Old May 5, 2008 | 08:05 AM
I think the only way you can repair a power antenna is by replacing the entire unit. I suppose there is a way to repair the actual motor or mast, but for the average hobbyist the best bet is replacing the entire unit.
Check out Fusick, Kanter, and Year One for parts. They might have what you need.
RandyS
Mar 1, 2013 01:55 PM
67delmont330
Nov 18, 2011 01:40 PM
Southbayolds
Nov 7, 2010 09:27 AM
Higgins
Jun 14, 2010 05:54 AM
aliensatemybuick
May 2, 2010 04:51 PM
