Help with creaking passenger side door
Getting kinda bad, is it just the door pins? Leaks when i pressure wash it as well. Its an 87 Cutlass Supreme, how do i quiet the noisey wipers? Bought new blades and those springs, did`nt help. any suggestions?
You can get new pins for your doors. I think most local auto parts stores carry kits to put new pins and bushings in the door hinges. It isn't very hard to change. All you need is a buddy around to help you hold the door.
As far as wipers are concerned, if your wipers squeak I suggest buying a new pair of blades. If it isn't the blades that are squeaking then you can always lube the mechanism with some grease.
If the wipers are vibrating/jumping on the windshield and new blades and cleaning the glass does not help, check the following:
1-Enough tension from the spring to hold them down on the glass.
2-Make sure the arm is not bent, causing the blade to be angled from top or bottom.
If these are okay, the pivot point on the arm is worn, causing the new blade to fit too loosely, enabling it to jump and chatter on the glass. My 97 Caddy had this problem and the dealer could not (or wanted to) figure it out. Too bad I figured it out AFTER the warranty expired...
Keep in mind junkyard arms ~may~ be worn also...
cessna195
Oct 29, 2010 08:13 AM
