Body work questions - I'm in way over my head here!!!
Old Mar 16, 2008 | 04:20 PM
esisson's Avatar
Project is starting all wrong.
First Question - 5 out of 8 of my body mount cage nuts are spun. Is my only option to cut the floor pan and trunk?? Is this a common problem?
Second Question - My RH front body mount has collapased allowing the body to sit directly on the frame. The rubber body/frame mount cushion is actually inside of the body mount with a chunk of metal bolted to it. Any ideas for a fix would be greatly appreicated. Any idea other than the obvious - Hire a professional! Thanks in advance.
68 442 convertible - Louisville, Ky.
Old Mar 16, 2008 | 07:11 PM
Unfortunately, I've not found a better way. Yes, it's very common for cars from the rust belt. While it's probably too late for you, I learned the hard way that an impact wrench is less likely to break the cage nuts loose than a breaker bar. Apparently the shocks from the impact loosen the rust between the bolt and the nut.
I've not seen that before. I assume you're talking about the boxed mounts at the base of the firewall? This is troublesome because it may indicate that your entire body shell is twisted. You'll need to cut and paste new metal to rebuild the mount, then you'll need to take careful measurements to determine if the body shell is racked.
Old Mar 17, 2008 | 03:24 AM
esisson's Avatar
Thanks for your reply Joe!
Old Mar 17, 2008 | 12:13 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Try slipping some air wedges in between the body and frame to get some tension.
CLcutlass
Paint
28
Feb 6, 2020 05:57 PM
ATrain1
Non-Olds Engines
Jun 29, 2012 12:58 PM
Timmy T
Drivetrain/Differentials
Mar 27, 2012 11:29 AM
sethj78
Nov 5, 2011 06:21 AM
344870M
Aug 21, 2009 08:04 AM
