Door Handles Interchange
Old Feb 28, 2008 | 01:36 PM
bcg88's Avatar
The handles on my 69 Delta Convertible are quite pitted. I cannot find any on line for replacement.
I did find a thread on line that the outside door handles for 1968-72 Oldsmobile Cutlass, F85, and 442s interchange with 1965-70 Olds 88/Ninety Eight (front doors).
I figure this might be a less expensive easier route than re-chroming what I have. Anyone in the know? If so can you recommend a PN?
Old Feb 28, 2008 | 06:57 PM
ijasond's Avatar
Purveyor of Polyurethane
Usually the only difference between similar models is the angle at which they mount. The holes almost all line up, & you can swap the rods on the back. But if you put a handle on from a different model it might lean up or down a bit.
I temporarily mounted 66 Caprice handles on my 66 Delta 88 to fit everything when doing the bodywork & everything was fine except they slanted down a little bit. Just check the angle of the door skin where the handles attach.
Old Feb 10, 2009 | 07:21 PM
68/70 Cutlass's Avatar
I used some on my 70 that I got off of a 65 Tempest.
Old Feb 10, 2009 | 09:43 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
There's a 69 delta at the local jyard here. I'll check em out 4 ya next time I go.
HonestDave
Jun 27, 2013 07:19 PM
arodenhiser
Nov 2, 2010 07:57 AM
gbrewer
Jan 29, 2010 02:46 AM
442_Mustang
Body work
Aug 17, 2009 07:28 PM
Big Joe P
May 23, 2007 01:18 AM
