Body Dolly
Old March 28th, 2015, 12:19 PM
servexcell's Avatar
Body Dolly
I have a 68 Cutlass Convertible , the body is ready to be removed from the frame just have 2 more bolts to remove.
Does anyone have recommendations of what i can use as a body dolly.
Bruce
servexcell is offline
Old March 28th, 2015, 05:24 PM
RonFX's Avatar
body dolly
Hello:
I built mine w/ 2x6 and 2x8 lumber all bolted together w/ carriage bolts, I bought wheels from Harbor Freight to make it roll and swivel around. Plenty heavy enough to roll onto a flat bed and go to the blaster and back and a couple other trips, I have less than $125.00 in it. Hope this helps.
Thanks, Ron
RonFX is offline
Old March 29th, 2015, 05:51 AM
GlennLever's Avatar
Here is one I built
GlennLever is offline
Old March 29th, 2015, 07:29 AM
servexcell's Avatar
Thanks Glen and Ron. Ron do you have a picture of the one you made. Glen , were you able to fasten the body to it.
Bruce
Old March 29th, 2015, 07:38 AM
GlennLever's Avatar
Bruce
I did not fasten the body to it , just set it on it. It is now under at 1949 Chevy Fleetmaster.
Old March 29th, 2015, 09:28 AM
Shoveling Snow
Hairy Olds's Avatar
This is a dolly I built for my 67 Toronado. It doesn't look pretty but it was solid as a rock and I transported many time on a trailer with no difficulties. I did not bolt it to the body.
Hairy Olds is online now
Old March 30th, 2015, 04:08 AM
RonFX's Avatar
body dolly
Bruce
Hello:
My dolly is taller and longer than the one Hairy Olds posted, but same basic concept, mine is tall enough for chassis to roll under when we reset the body.
Thanks, Ron
RonFX is offline
Old March 30th, 2015, 04:11 AM
RonFX's Avatar
body dolly
Hey:
Forgot to mention, I strapped the body down w/ ratchet straps and a couple lag bolts thru floor pan into wood crossmember.
Thanks, Ron
RonFX is offline
Old March 30th, 2015, 04:32 AM
Rodney
cdrod's Avatar
Body cart
Bruce,
Here's a pic of my home made body cart. It's made of 2x6 and 4x4 blocks. I have is screwed down at the front torque boxes, but the rear mounts are not bolted down. Since the picture was taken, I've added larger 8" pneumatic casters from Harbor Freight and additional plywood bracing at the 4x4s. It's pretty solid and rolls easily with the larger casters.
cdrod is offline
Old April 1st, 2015, 12:50 AM
servexcell's Avatar
Rodney , would you have the measurements of the pieces of wood you cut with a diaghram as how and were each piece assembles. Mine is a 68 convert. the body should be the same dimensions.
Thanks Bruce
Old April 1st, 2015, 02:21 AM
Rodney
cdrod's Avatar
Bruce:
I didn't make a drawing before building the cart, I just measured the mounting points on the car and worked out the details on the fly. I can tell you this, the long 2x6s running front-to-back are 10' long and the 4x4 blocks are 10" tall. I have attached another pic showing the cart from the rear. The rear mounting points are inboard from the front mounts. To get the correct width and height I stacked two 2x6s (for strength) and added another 2x6 block to get the correct height. You could just cut the rear 4x4s 11.5" tall and eliminate the extra 2x6 block. I used large lag bolts to anchor the front mounts at the torque boxes, but there are cage nuts n the body at the rear mounts so lag bolts wouldn't work. To keep the body from sliding off in the rear I added 1x4s on either side of the 4x4 block and set them about 1" higher than the 4x4 so the body rail would sit in between the 1x4s and couldn't slide off sideways. I also added another triangular brace (not shown in this pic) across the rear 4x4 block and the sideways 2x6 to make the cart stronger.
Here's the rear pic.
cdrod is offline
Old April 1st, 2015, 04:24 AM
Shoveling Snow
Hairy Olds's Avatar
That is a pretty looking dolly.
Old April 5th, 2015, 06:33 PM
servexcell's Avatar
Thanks guys for your help , much appreciated. Thanks for the pictures especially Rodney's convert showing the body braces.
Bruce
WTony
January 5th, 2013 05:58 AM
L69
September 25th, 2012 08:20 AM
Allan R
November 20th, 2011 06:37 PM
<72S>
Drivetrain/Differentials
November 24th, 2010 07:01 PM
VikingBlue
August 26th, 2010 06:57 AM
Quick Reply: Body Dolly
