Rare 55 olds 2 door sedan with manual trans
Old November 14th, 2014, 09:52 AM
Scharpp
scharpp's Avatar
I have a 55 Olds 88 2 door sedan with 324 and three on the tree, was driven for 14 years, had valve problem from what im told, manifold in trunk but engine is locked up from setting, body is great and chrome is all there, rust hole in passenger frt floor board and in trunk floor, windshield and drivers door glass cracked, body has a very small spot showing on lower left frt fender, otherwise very solid, all original right down to the hub caps, interior is all there but aged, car appears never to have been wrecked except small damage to right rear 1/4 panel, first $4000.00 or best offer takes it home East Wenatchee Washington
http://s273.photobucket.com/user/gre...show/My%20cars
scharpp is offline
Old November 14th, 2014, 01:28 PM
Proud Viet Nam Veteran
redoldsman's Avatar
You have a pretty rare bird there. The engine is the big question. You can spend several thousand dollar rebuilding a 324. That could really be a fun car. She looks pretty solid.
redoldsman is online now
Old November 14th, 2014, 01:51 PM
Tedd Thompson's Avatar
As redoldsman said not many manual trans cars were made in 55. Could make a great project car
It may help you sell that car if you could get it unstuck. A little Mystery oil down the spark plug holes, let her sit for a day or two and it could free it's self up with out much problem. There would be a larger market for a car that will at least turn over..... Just my thoughts...Tedd
Tedd Thompson is online now
Old November 14th, 2014, 01:54 PM
That'll make a nice project. Good luck with your sale.
oldcutlass is offline
Old November 17th, 2014, 09:35 AM
Registered car nut
nonhog's Avatar
Cool car! Heres a bump for ya!
nonhog is offline
Old November 17th, 2014, 12:28 PM
garcar's Avatar
Does anyone have a feel for the number of 1955 88 2 door Sedans that might have been produced with manual transmissions? I have one down here in Australia, and am keen to know.
garcar is offline
Old November 18th, 2014, 05:56 PM
68conv455's Avatar
Sweet car. Too bad you are on the wrong coast.
68conv455 is offline
Old November 20th, 2014, 08:17 AM
goodkarmech's Avatar
If you have the time & spend a little effort you can possibly unstick the motor.
Might not be too stuck if stored inside the whole time.
Obviously you will get more for the car if it turns over...
goodkarmech is offline
Old November 20th, 2014, 09:35 AM
Scharpp
scharpp's Avatar
I will be working on getting the motor unstuck, thanks for your input, also on your question on how many with manual trans made, I cannot find it now but I may be wrong but I believe I read somewhere there were only like 300 1955 2 door 88 sedans with manual trans made, that seems low as there were 37,507 made
http://auto.howstuffworks.com/1954-1956-oldsmobile5.htm
scharpp is offline
Old November 20th, 2014, 09:44 AM
Scharpp
scharpp's Avatar
stuck motor
Heres a story for ya, I just had the same problem with a 50 plymouth coupe with flathead six, the motor was rebuilt and ran for 45 minutes, then the guy let it set for 8 years without starting, motor was locked solid, I put marvel in cylinders and filled crankcase with diesel, sat for a month, got a socket, breaker bar and big pipe and it came loose, when I went to start it, it didn't even make 1 revolution and fired right up, it runs great, that made me happy, hopefully the same will work with the olds
scharpp is offline
Old November 20th, 2014, 01:58 PM
I don't have any good numbers to quote but I personally know of three 88's with manual transmissions my self. Although Oldsmobile thought highly of their four speed automatic and promoted it accordingly I would think only 300 standards would be a very low number.....Just a thought...Tedd
Old November 20th, 2014, 05:50 PM
ferndaleflyer's Avatar
I also have whats left of one in the barn in WV. Not much left of it as we have sold parts off of it for 30 years I suppose----to hard to get to to even scrap it.
ferndaleflyer is offline
Old November 21st, 2014, 01:54 PM
Scharpp
scharpp's Avatar
HOws the trunk floor pan in your olds you have been parting out?
scharpp is offline
scharpp
December 18th, 2014 11:33 AM
elpresidente
October 21st, 2014 04:03 AM
oldsmosteel
February 28th, 2013 07:18 AM
4Door67
June 8th, 2012 12:05 PM
Quick Reply: Rare 55 olds 2 door sedan with manual trans
