Brake Issue
Old March 23rd, 2015, 02:08 PM
ollerich29's Avatar
Brake Issue
I installed new shoes and drums on my car, and the brakes still work but it takes a few pumps to get the pressure up and the pressure slowly goes away when my foot is not on the brake. I can hold the pedal down and still have pressure, it just goes away in between when I use them. The pressure held fine before and I never touched any of the lines.
ollerich29 is offline
Old March 23rd, 2015, 03:24 PM
You need to bleed them.
oldcutlass is online now
Old March 23rd, 2015, 03:49 PM
jcdynamic88's Avatar
brake issue
most likely you need to adjust the shoes a little tighter to the drums. you should be able to hear them making contact with a little drag. with new shoes you can make them a little tighter than an old set.
jcdynamic88 is offline
Old March 25th, 2015, 05:01 PM
ollerich29's Avatar
I adjusted the brakes so they are just barely touching still the same result on the pedal. So I went to bleed them, had my wife pumping, and the driver side went fine. Went over to do the passenger side and the bleeder valve twisted off like it was 45 years old, so any ideas on how to get that out would be very much appreciated.
Old March 25th, 2015, 05:09 PM
Just replace the wheel cylinder.
It's ten times easier than drilling out the bleeder, and they're only $10-$20, depending on brand.
... But be ready to change the brake line if you can't get it out of the cylinder...
MDchanic is offline
Old March 25th, 2015, 05:29 PM
ollerich29's Avatar
Sounds easier and cheaper than what I was picturing.
Old March 25th, 2015, 07:24 PM
Or you can tale it off and use an easy out. It will probably come right out and then you can put in a new one.
Old March 25th, 2015, 08:08 PM
Maybe.
But I'd be ready with the cylinder and the brake line.
MDchanic is offline
Old March 25th, 2015, 10:23 PM
Be sure to use a tubing wrench / line wrench on the brake line fitting. I rounded off a few of those trying to loosen them with a regular open end wrench.
Fun71 is offline
Old March 26th, 2015, 07:07 AM
I use 6pt ignition wrenches when I bleed mine.
Old March 26th, 2015, 10:36 AM
ollerich29's Avatar
Thank you i will get a cylinder and a couple hoses the driver side hose is in tough shape
Old March 26th, 2015, 10:52 AM
Don R.'s Avatar
When you did the shoe replacement did you pull back the cylinder dust boots to check for leakage? From what you describe it sounds like the hydraulic system hasn't been serviced in a long time. If that is true I would seriously recommend replacing all wheel cylinders, all hoses, and the master cylinder with new parts. That is cheap insurance against future failures.
Don R. is offline
Old March 27th, 2015, 07:52 AM
ollerich29's Avatar
The passenger side cylinder was wet around the boot, so I am going to get the parts and fluid I need to redo the hydraulics.
Old March 27th, 2015, 07:58 AM
Macadoo's Avatar
If you do end up replacing the master cylinder, keep your old cap. I replaced mine with an Advance Auto part and the cap leaked, even tried replacing the new gasket. Put my old cap on it and haven't had a problem since.
I replaced my wheel cylinders when I did my brakes. It was easy-peasy, even with 44 year old connections. But yeah, I used the proper wrenches on the lines.
Macadoo is offline
Old March 27th, 2015, 10:40 AM
ollerich29's Avatar
Does anyone have an idea how much brake fluid I would need to fill it back up?
Old March 27th, 2015, 10:43 AM
Get a quart. That should be more than enough.
MDchanic is offline
Old March 27th, 2015, 10:45 AM
ollerich29's Avatar
Thank you all for your help.
Old March 28th, 2015, 11:41 AM
ollerich29's Avatar
Just got everything put back together and the brakes work like a champ thank you for all your help now on to the fuel pump.
Old March 28th, 2015, 12:28 PM
You're welcome. Always glad to help out!
MDchanic is offline
Old March 28th, 2015, 02:14 PM
Well done
1yesfan
August 4th, 2015 06:40 PM
Dead Reckon
July 14th, 2014 02:35 PM
WiSeGuY
Brakes/Hydraulic Systems
November 7th, 2013 02:09 PM
dan68toro
August 12th, 2008 11:27 AM
54olds
June 25th, 2008 12:46 AM
Quick Reply: Brake Issue
