Brake bleeding
Old May 10, 2008 | 11:00 AM
projectheaven's Avatar
Brake bleeding
What is gravity brake bleeding?
Old May 11, 2008 | 02:59 PM
Oldsguy's Avatar
Past Administrator
Opening the bleed nuts, taking the lid off the master cylinder, and letting gravity to it's thing. I have never done it that way but many people here have and like to do it that way. I used to have my wife do the foot pumping for me but she isn't strong enough now to hold it down (can't drive any longer either do to weakness in her legs) so I have to enlist the help of someone else or do the gravity thing or get one of those one-man brake bleed kits.
Old May 12, 2008 | 03:52 AM
Modern Motoring's Avatar
I have used the poor mans brake bleeder.. a BROOM STICK ! pump up three times, wedge the broom stick between the pedal and the seat, go and open up the bleeder valve. It's a lot of work but when you don't have someone around to help and you can't find your one man bleeder tool, it works !
Old May 12, 2008 | 06:04 AM
Oldsguy's Avatar
Past Administrator
I tried the broomstick once but it dropped loose the first time, there was lots of air in the system. Instead, a short chunk of 1x12 long enough to leverage the pedal weighted by a cinder block; or just a cinder block depending on the car.
Old May 15, 2008 | 01:11 PM
I had my now ex wife help me bleed the brakes once. I told her to pump three times and hold it. She heard "pump three times". I had more air in that system.....
Macadoo
Brakes/Hydraulic Systems
38
Jul 6, 2014 04:58 AM
brown7373
Mar 20, 2014 06:14 AM
PhilGGG
Dec 18, 2013 07:06 PM
Deputy442
Sep 5, 2008 05:15 PM
Bluevista
May 21, 2008 10:20 AM
