help! front brakes pulling left
Old Apr 24, 2009 | 04:50 PM
IDAS 69's Avatar
I have a 69 442 and when I apply my brakes they pull to the left. Running 50-60 I'd be in real trouble in a panic stop. Can anyone determine this cause? Thanks Eddie
Old Apr 24, 2009 | 05:07 PM
csstrux's Avatar
Had a skylark did the same thing only to the right. Opened the drums up and drivers side was completely inoperative. do you have disks or drums, and have you checked hydrolics for clogging or inoperative caliper, or brake cylinder. Rust can jam things up pretty tight
Old Apr 24, 2009 | 05:59 PM
Lady72nRob71's Avatar
If you find nothing obvious (like stuck rusty parts, brake fluid leaks on the linings, etc) and after disassembling, cleaning, lubing and reassembling, the brake hoses might be deteriorating from the inside and are acting like one-way check valves... My old Ford did that after 25 years...
Old Apr 24, 2009 | 06:24 PM
OLD SKL 69's Avatar
GM Enthusiast
If you have disc brakes up front make sure the pads have not become contaminated with grease or brake fluid. I have seen grease seals go bad and it will start coming out and cause this to happen.
Old Apr 24, 2009 | 08:47 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I have had the hoses do what Rob is talking about. Usually if they do this, the brake on that side will get very hot since the pressure does not release. You will not go very far.
Old May 1, 2009 | 06:09 PM
IDAS 69's Avatar
I have drums. All usefull information. I'll be tearing them apart this week-end. Thanks for all the info.
Eddie
Old May 28, 2009 | 06:41 PM
IDAS 69's Avatar
Found cause for pulling left.... Replaced left ball joint....FIXED.... Thank God....
Old Jun 8, 2009 | 05:06 PM
joades's Avatar
ZATBAD 72
I just replaced my front brakes on my '72 and now have the same problem - pulling left. I replaced pads and rotors. It does not do it every time I hit the brakes, but when it does it pulls pretty hard. I lubed the ball joints when I had everything apart. I am curious on the note above how the ball joint caused your problem. Also curious if anyone has an idea on a disc car what would cause this intermitantly.
Old Jun 8, 2009 | 05:30 PM
IDAS 69's Avatar
Found cause for MINE pulling left.... Replaced left ball joint....FIXED, But I have drums. Still hope It helps. Check your ball joints....
Old Jun 8, 2009 | 05:34 PM
IDAS 69's Avatar
Well that's what the guy told me. Did I get ripped off. Lets hear from the experts...Please....Now I'm worried... Maybe he adjusted my left drum and charged me 170.00. Thanks
Old Jun 9, 2009 | 07:49 PM
88 coupe's Avatar
Junior Member
Originally Posted by joades
........ curious on the note above how the ball joint caused your problem ........
Sloppy ball joint causes the alignment to move when the brakes are applied.
Originally Posted by IDAS 69
........ Did I get ripped off ........
Did you inspect the old part? Is your "pulling" issue cured?
Norm
Old Jun 10, 2009 | 02:36 AM
Yellowstatue's Avatar
Smile Left turn Clyde
My '57 pulls to the left...because the right wheel cylinder is seized..
cmpeavler
Brakes/Hydraulic Systems
20
Oct 6, 2013 06:50 PM
anthonyc
Aug 9, 2010 08:48 PM
denf221
May 2, 2010 06:39 PM
IDAS 69
Jun 3, 2008 12:40 PM
