Practical advise on setting a proportioning valve
Old September 2nd, 2016, 01:44 PM
boese1978's Avatar
System operation understood...my conversion to front disc from all drum includes a Summit Prop. valve.- mounted on the tub. Anyone done similar, how did you go about adjusting/setting the valve? did you do it on a wet road? on the grass? a couple people watching for the wheels to lock up? Is there a non driving ie: mechanical way to do it with a "tool"? or is it a matter of trial and error?
Thanks!
Make that "advice" in the subject line
boese1978 is offline
Old September 2nd, 2016, 04:51 PM
Unfortunately, everything I've ever read is trial-and-error on dry, flat pavement. You can make an initial setting with a brake pressure gauge, but ultimately you need to go out and make a bunch of panic stops on a deserted stretch of road or parking lot.
http://www.superchevy.com/how-to/713...tioning-valve/
joe_padavano is offline
Old September 2nd, 2016, 08:09 PM
boese1978's Avatar
Thanks Joe. Sounds like a "fun" task.......
oldspackrat
October 29th, 2017 07:38 PM
Mike H.
Brakes/Hydraulic Systems
March 7th, 2013 10:48 AM
Chumley
March 1st, 2008 05:24 PM
Chumley
February 2nd, 2008 04:35 PM
W30post
November 25th, 2007 10:18 AM
Quick Reply: Practical advise on setting a proportioning valve
