1961 Master Cylinder Conversion
Old October 30th, 2007, 10:11 AM
KQQLCAT's Avatar
I want to convert my master cylinder to a dual reservior. Has anyone done this on a 61 Olds with the 4 bolt pattern.
Pat
KQQLCAT is offline
Old October 30th, 2007, 11:36 AM
KQQLCAT's Avatar
It would be great if you could find out.
KQQLCAT is offline
Old November 6th, 2016, 04:26 PM
Sleepybeaver's Avatar
Was there no feedback
Sleepybeaver is offline
Old November 7th, 2016, 06:21 AM
Run to Rund's Avatar
answered other thread: If two of the bolts/studs are in the right positions, just use them. Also make sure the pushrod length is correct for the new plunger and the distance it must travel. You can use a longer pushrod with a bolt pattern adapter (make it yourself) if needed.
Run to Rund is offline
Old November 7th, 2016, 10:07 AM
If you type 1961 oldsmobile master cylinder into Google, you get this thread on H.A.M.B. that answers your questions.
joe_padavano is offline
Old November 7th, 2016, 02:58 PM
Thanks for the reply
I read that thread and it was more for disc brake conversion.....I'm staying with all drums .I did read but without very much info on the 66 cadillac m/c.....continued searching and found a number on a guy named Craig Stanley out in New York and I spoke to him today...what a great guy on the phone and very helpful....and I must say, spoke highly of you as well....
He got me set up with what I needed for direct bolt on and I don't even have to change out the rod or the booster...it's a direct bolt on minus the lines of course...I couldn't be happier to get started on it.....i sent him a postal money order today ....
Thank you all for the replys
I hope this help others when wanting to convert single m/c to dual m/c with keeping there existing vacuum booster
Old November 7th, 2016, 03:09 PM
Originally Posted by Sleepybeaver
Thcontinued searching and found a number on a guy named Craig Stanley out in New York and I spoke to him today...what a great guy on the phone and very helpful....and I must say, spoke highly of you as well....
Craig is Mobileparts on this site. He's got a wide variety of hard to find brake, steering, and suspension parts. He fixed me up with unobtainium pieces for my 67 Delta.
As for the H.A.M.B. article, the GM disk and drum master cylinders interchange on the booster. Simply using that booster with a drum/drum master would also have worked. Pretty much ever GM dual master cylinder from 1967 through the 1990s has the same bolt pattern.
Old November 7th, 2016, 04:45 PM
Gotcha ....thanks for the info
young olds
November 21st, 2022 03:09 PM
Jakespeed63
August 25th, 2015 12:20 PM
twintracks
Brakes/Hydraulic Systems
March 15th, 2014 11:09 AM
<marksz71>
October 20th, 2006 07:14 PM
martine
February 5th, 2004 10:28 AM
Quick Reply: 1961 Master Cylinder Conversion
