1956 Olds 98 Brakes Master cylinder fill cap
Old October 21st, 2021, 11:46 AM
Jonclev86's Avatar
I can not get the fill cap off of my 1956 Olds master cylinder. (See pic for what I'm talking about). I feel like I'm going to break it if I keep twisting on it.
Is there any secret to getting the cap off? Any advice will be appreciated.
* I found this pic in the internet*
Jonclev86 is offline
Old October 21st, 2021, 12:44 PM
WHIPOLDS's Avatar
I just went through that problem yesterday. I had to use pliers because just trying it with my hand it would not budge. It did come off with some pressure but like you I was afraid it would snap. I put a small amount of anti seize on the threads. Can you try soaking with penetrating oil? Welcome to the forum! You will finds lots of help here.
Good luck
Rick
WHIPOLDS is offline
Old October 21st, 2021, 01:07 PM
Jonclev86's Avatar
Thanks Rick,
Actually I just got it off. I sprayed WD-40 on for the last 2 days and let it set. I was afraid it was going to snap but it magically it just came off. I cleaned the threads and soaked it again with cleaner and WD-40. So I'm all good for now. Thanks Again!
sgolds
February 7th, 2021 01:50 PM
72455
October 14th, 2019 07:33 PM
Brad Chapin
July 30th, 2019 12:42 PM
junior supercar
October 19th, 2015 08:15 PM
rpc45040
October 18th, 2010 07:37 PM
Quick Reply: 1956 Olds 98 Brakes Master cylinder fill cap
