Rallye 350 drivers fender/door gap
Old February 24th, 2017, 07:26 PM
jonesolds442's Avatar
Hello everyone,
After reading several other related threads, I'm hoping for some additional clarification. The pics show a wide-to-narrow gap issue and the corresponding fender-to-hood gap. The fender-to-hood is an easy fix, but the door-to-fender adjustment is somewhat confusing.
I've loosened the core-to-fender, cowl-to-fender, hood hinge, and post bolts, but I don't see how I can tilt the fender when the core-to-fender holes are not oval-shaped to allow for lateral movement.
As an aside, this gap was almost perfect before, but it had suddenly shifted because (as I have recently discovered) my paint/body man did a substandard job.
I'm reticent about getting too forceful as the remaining gaps on the car are pretty good.
Another thread suggested using a jack to tilt the frame. Someone also suggested adjusting the core support (that's the least attractive option). Several others had said just to let it go, but as you can see, this is way too obvious.
jonesolds442 is offline
Old February 25th, 2017, 04:33 AM
I would think some shims under the core support would correct the door gap and shifting everything (facing the front) to the left a smidge will correct the hood gap.
oldcutlass is offline
Old February 25th, 2017, 05:21 AM
68442's Avatar
When shimming the core support pay attention to the fan against the shroud(Clearance).
68442 is offline
August 22nd, 2019 08:45 AM
VAS442
June 22nd, 2016 04:50 PM
Cutlass455
September 27th, 2015 01:33 PM
sklbndt
Body work
March 25th, 2015 08:10 PM
jeffsims
Body work
June 4th, 2014 05:16 PM
Quick Reply: Rallye 350 drivers fender/door gap
