1968 Cutlass Trim Removal
Old Dec 30, 2009 | 06:41 PM
1968Cutlassfallbrook's Avatar
Hello,
I own a 1968 Cutlass S. I have the orginal trim still on it from the fenders and all the way to the back. I was wondering how these are removed without breaking them? I'm wanting to take them off so that I can strip the car down to bare metal as the paint has cracked from age as I believe this to be the second paint job on the car. Any ideas how these are removed? I noticed the fender moldings have bolts holding them. Also does the headlights need to be removed to remove the fender as I have rust on the passenger fender and would like to get it corrected without it on the car or is it better on the car? Also have the vinyl roof moldings as well. Is there a site to figure out what the orginal factory colors would of been? Thanks
John
Old Dec 30, 2009 | 08:09 PM
jaunty75's Avatar
First, if you don't already have them, a chassis service manual and a body sevrice manual would be good to have. The body service manual would be invaluable in showing you how to remove body panels. I wouldn't even attempt to do what you are proposing without having these available.
Second, if you post what's written on the body info tag, which is located on the driver's side of the firewall in the engine compartment usually just below the windshield wiper motor, several people on here will be able to decode it for you and tell you what the original colors were. It'll just be a series of letters and numbers in several rows. Write down everything you see and post it here in the order it appears on the tag.
Old Dec 31, 2009 | 12:23 PM
07E 027161 370001
ST 6S-33537 6706G57 Body
TR 930 B60 P2 Paint
I believe that's what it says on the cowl it's hard to read I had to use a pencil to get those numbers I know the top is correct and the paint numbers are but the others not 100% Thanks
Old Dec 31, 2009 | 12:29 PM
jaunty75's Avatar
Originally Posted by 1968Cutlassfallbrook
07E 027161 370001
TR 930 B60 P2 Paint
Thanks. I don't have the code books, so I can't decipher this, but others have on here, and I'm sure they'll check in with data for you.
I can say that, in your second line, that ST-6S should be ST-68, as the 68 is the year of your car. Also, the 07E indicates that your car was built in the 5th of week of July, and I'm assuming that would be July 1968, which would make it a very late in the model year car.
Unless it means July 1967, which means it was built very early in the model year. I don't know how early in 1967 production switched to the '68s. Late July/early August seems about right. Again, I'm guessing others on here will know.
Old Dec 31, 2009 | 12:42 PM
07E 027161 370001
ST 68-33687 BF06857 Body
TR 950 B80 P2
I was able to clean it up a bit and got better numbers and letters. I believe this is what shows on the cowl..
Old Dec 31, 2009 | 02:00 PM
My442's Avatar
Get a Fisher Body manual.
It shows all the trim mounting, window adjustments, interior, etc.
c294mpd
Feb 14, 2016 04:18 PM
oldspackrat
Apr 4, 2014 09:39 PM
Jul 28, 2011 10:55 AM
Oct 30, 2009 09:05 PM
mikeraines63
Jul 4, 2008 03:23 PM
