Trunk Release
Old September 9th, 2016, 08:11 AM
Fizz's Avatar
Trunk Release
So not having the trunk keys for the new build (1965 98 LS, 4dr ht) I decide to drill out lock and now cannot open trunk, what do I do to open it
Fizz is offline
Old September 9th, 2016, 08:16 AM
lemoldsnut's Avatar
take out the back seat. Then use a few extensions on a socket I tape the socket to the extension and at each extension junction. Take out the two bolts on the lower side where the trunk latch connects to the latch receiver on the lower side. it will open then. If you had done that first there would be no need to drill out the cylinder.
lemoldsnut is offline
Old September 9th, 2016, 11:04 AM
Oldsdruid
rocketraider's Avatar
Any chance car has a power trunk release? Look for a button in the glove box. It's vacuum operated so you'll need a vacuum source. Hook up vacuum source, push button and decklid should open.
rocketraider is offline
Old September 9th, 2016, 11:51 AM
m371961's Avatar
Guess it is too late, but can't one remove the glove box lock and get the key code there?
m371961 is offline
Old September 9th, 2016, 07:23 PM
Randy C.
rcorrigan5's Avatar
I saw a locksmith do this to my '69 4-4-2 when the trunk lock seized and the key would not work. He gently raised the bezel that goes around the locking mechanism by sliding a small blade between the inner edge of the bezel and the lock. After he had a small segment of it raised, he got a hold of it with needle nose pliers, tore into the edge of the bezel, and just worked the tear around the bezel until it was torn to the outer edge. Once torn to the outer edge, he was able to remove the bezel and then the lock cylinder came out. Once the lock cylinder came out, he drilled through the end of the lock cylinder casing, which eventually gave him access to the trunk lock after clearing what was in the way. With the trunk lock mechanism visible, he just stuck a flat blade screwdriver into it to open the trunk lid. Of course, I had to get a new lock assembly but the locksmith had it available and keyed it to my original key.
Randy C.
rcorrigan5 is online now
Old October 17th, 2016, 09:22 AM
Fizz's Avatar
Talking Never enough extensions
First off, thanks for the replies and advise. I ended up going the route of the extensions and pulling the lock assembly off from the back, boy that was a lot of extensions, that trunk has to be 7'-8' long. Now the next question if anybody knows, trying to get the ignition switch out and the threads on the original module are rusted on and the entire dash seems to be one solid pressed piece of steel with a few small cutouts for accessories, this thing is built like a tank. I have a new ignition module and cylinder but no way to get the old one out, and after a day of laying upside down.... I am ready to take a grinder to it to cut it out(not really), but any thoughts or words of wisdom would be greatly appreciated... thanks again
Fizz is offline
Old October 17th, 2016, 10:32 AM
m371961's Avatar
I take it that you have removed the lock cylinder and the bevel will not unscrew?
m371961 is offline
Old October 17th, 2016, 11:21 AM
Fizz's Avatar
I tried to get the lock cylinder out by putting a clip in the small hole adjacent to the keyhole and working it back to the accessory slot, it will not move, seems like it is froze completely up
Fizz is offline
Old October 17th, 2016, 12:56 PM
m371961's Avatar
You have to remove the cylinder first, the bezel will not come out with it in.
I will check the CSM, (you do have one don't you?), I believe you turn the key to ACC, insert paper clip in hole, then pull out.
m371961 is offline
Old October 17th, 2016, 01:14 PM
m371961's Avatar
Checked, page 12-106 CSM, Insert key, turn to ACC, insert wire in hole, turn key counter clockwise and pull out. You will have to play with it a bit, but it should pop out.
m371961 is offline
Old October 17th, 2016, 02:07 PM
Fizz's Avatar
I don't have a CSM, when I went to their website, I can't even order one, where do I get one?, as I mentioned earlier, I am relatively new to the restoration hobby and appreciate the help
Fizz is offline
Old October 17th, 2016, 03:09 PM
m371961's Avatar
E-bay for originals. They are best. I use a digital one, from Dave Graham.http://davegrahamauto.com/
Some don't like them, but mine is good. You need the Chassis Service Manual and the Fischer body manual. Do not waste money on anything but factory manuals.(Haynes, Chilton, etc.)
A factory manual is a must, even if someone else does the work for you. They don't know 50 year old cars.
There are aftermarket factory manuals, but reprints can be a problem as also with digitals. Rock auto has reprints and Dave graham cd
m371961 is offline
Old October 17th, 2016, 03:25 PM
Olds Fever
CRUZN 66's Avatar
I have the Chassis Service Manual & the Body Service Manual listed in the parts for sale classifieds, but you did not say where you are located and for the most part I only ship within the US:
https://classicoldsmobile.com/forums...y-manuals.html
CRUZN 66 is offline
Old October 17th, 2016, 04:52 PM
m371961's Avatar
There you go Fizz. Nice price for both
m371961 is offline
DRXOLDS
October 13th, 2013 01:38 AM
Olds luvr
January 25th, 2009 08:10 PM
KQQLCAT
October 20th, 2008 07:21 AM
KQQLCAT
September 2nd, 2008 10:12 AM
1965_F85
April 21st, 2007 02:03 PM
Quick Reply: Trunk Release
