Smoking after camshaft replacement.
Old Oct 18, 2008 | 10:52 AM
Vincent Woodard's Avatar
First i would like to say hello to all. This is my first time posting a thread so bear with me. I have a 1972 cutlass, 750 edel. carb,455 C-heads,4spd,limited-slip diff, stock gears. Before the cam swap the engine ran fine. Now it lightly smokes constantly. Is the any simular situations out there. The smell tends to burn your eyes if you hang around.
Old Oct 18, 2008 | 01:21 PM
Smokes out the exhaust or at the engine? If out the exhaust, I'd guess that the intake gasket is leaking underneath, allowing oil from the lifter valley to be sucked into the intake. If the smoke is from around the engine, then the valve covers are likely leaking.
Arrowstorm
Suspension & Handling
25
Jul 29, 2015 05:52 AM
BAFRAYD
May 20, 2014 02:35 PM
Gaz Hog
Mar 22, 2009 03:39 PM
Redog
Mar 11, 2008 10:37 AM
dynamic88
Jun 3, 2007 01:00 PM
