70 olds 455-exhaust manifolds
Old Jul 15, 2008 | 12:17 PM
olds4life's Avatar
hey olds nation. need a set of exhaust manifolds for a 70 455. i'm located in st. louis, missery. wghaskins@yahoo.com thanks
Old Jul 15, 2008 | 01:56 PM
Thorton makes reproduction W and Z manifolds. They also make a driver's side manifold for the full sized cars. However, they are pricey. I will also need stock manifolds when I am ready to put my engine in the car. I broke off an EZ Out in one and the other is cracked.
Old Jul 15, 2008 | 03:08 PM
citcapp's Avatar
I bought a set of the W-Z exhaust manifolds on e-bay for $175.00 including shipping. Took about a month of checking, several sets showed up but many of them had broken tabs
Old Jul 15, 2008 | 04:38 PM
The other problem with used manifolds is that there can be heavy rust pitting, particularly under the heat riser stove where moisture can get trapped.
Old Jul 15, 2008 | 07:34 PM
Run to Rund's Avatar
That's why I have been saving a couple sets from the desert southwest--no nasty corrosion! Don't know what I'll ever use them for. . .
dahl1car
Nov 22, 2012 08:59 AM
monzaz
May 15, 2012 01:23 AM
buickfarmer
Dec 8, 2010 12:42 PM
68/70 Cutlass
Apr 14, 2009 05:25 PM
citcapp
Nov 26, 2007 07:54 AM
