Carburetor Conundrum
Old Jan 28, 2008 | 06:07 PM
Coltonis's Avatar
So I've been working on my car ('70 cutlass w/ '73 455 w/ '78 Rochester Q-jet) a little more (trying to get it running) and it seems my carb not only leaves a LAKE of fuel in my manifold but the throttle pump lever is cracking off aswell! Enter the Friend of a Friend. Says he has a 1970 455 High output engine (E heads) out of an RV missing the manifold in Fair/Good condition... wants $500. I'm guessing him saying High Output simply means its a marine motor? *Ideally* I would like to get a Carb that will get my current '73 engine running so that I can buy the '70 455, rebuild it, and just transfer the carburetor to the new engine. Any suggestions on a carb that could work? Interested in best bang for the buck. Also as far as Intake Manifold for the rebuild could/should I steal it off of the '73? OR My searching came up with good things about Edelbrock O4B, but my car already has HEI and I heard things won't fit.
Old Jan 29, 2008 | 03:01 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. First, the carb. Where exactly is the fuel coming from? Is it a line leak, or coming from the top of the carb? Will it even start?
Let us know.
Old Jan 29, 2008 | 09:49 AM
Coltonis's Avatar
It started a few times (right after I replaced all the fouled spark plugs and removed the carb for the first time). There was some grit in the bottom of the float bowl but I didn't have carb cleaner and at the time didn't quite grasp severity. Every time it started though it would race for like a minute, maybe less, until it would die. Won't start at all as of the last time we tried but that was when we discovereed the whole gasoline lake situation in the manifold. I THINK we concluded it was that the choke wasn't releasing(?) and it was just sucking down fuel. (I'll have to double check with my slightly more knowledgeable friend who was helping me.) He suggested my options being get a rebuild kit for it, or get a holley that will work for my engine.(He claims the only people who like rochesters are Oldsmobile guys, LOL!) Since the top plate is cracked (one of the little cast-in supports for throttle pump lever) I figured I would see what you guys thought about a new carb.
Old Jan 30, 2008 | 05:18 AM
If you could post a pic or two of the damaged carburetor that would help. I am having trouble visualizing what part of the carburetor is broken. Your best bet would probably be to get a remanufactured Quadrajet from the parts store and turn in the one you have as a core.
BTW, tell your friend that he must be smoking some good stuff if he likes Holleys. They are POS'. Quadrajets are where it is at!
Old Jan 30, 2008 | 07:44 AM
Coltonis's Avatar
Sure thing, I'll get some pics and post them this evening
Old Jan 30, 2008 | 09:35 AM
Oldsguy's Avatar
Past Administrator
You mentioned grit in the bottom of the bowl. If that is true, you may have a damaged needle and seat assembly from the bad fuel. This could be causing the puddle of fuel you described. I would recommend you look close at your fuel system when you correct your carburetor problem. You may have rust in the fuel tank, rusty fuel lines, bad filters (or none), or all at the same time. Danny Sarvis might be able to help you with your carburetor, he rebuilds them and as usual, I can't remember his username here on this site. Somebody help me out.
70Wcars (see below)
Old Jan 30, 2008 | 08:40 PM
70Wcars's Avatar
Grit or trash in the fuel bowl almost always gets lodged in the inlet seat under the needle and will cause flooding. If the top is taken off the carb and the float bowl cleaned, and the needle and seat are replaced...and a new fuel filter installed...and this same symptom occurs again...then the fuel lines or tank are rusted/corroded and need to be looked at. Good idea to rplace the float while the top is off the carb as well.
And to your buddy who runs Holleys...11.43 with a Q-jet in my '70......tighten up the converter and this car can cruise on the street...
Hope this helps
Danny
Old Jan 30, 2008 | 09:31 PM
Coltonis's Avatar
Ok I got the pics posted, they're like uber-resolution, so beware!
This is my carb...
http://members.***.net/boondock/Carburetor/Carb1.jpg
This is the Stamp on the side...
http://members.***.net/boondock/Carb...rb_Numbers.JPG
This is a side shot... note the washer on the bottom screw (evidence its been dicked-with)
http://members.***.net/boondock/Carb.../Carb_Side.JPG
This is a shot from the back just in case there is something important that I don't know about back there...
http://members.***.net/boondock/Carb.../Carb_back.JPG
This is a crude dipiction of the cast lever support that is broke... The red line is where its cracked almost completely through; its held on by a tiny piece on the edge. ANY throttle mechanism movement would cause it to break off, I had to put an oversize Paper clippy on it to keep it in place when we tested it...
http://members.***.net/boondock/Carb...Carb_Broke.JPG
This is my Lakeside view, its been about 2 or 3 days with the carb off so most of the fuel puddle has either evaporated or trickled down but its still obvious the difference between sides (Note:Bottom of Pic=Front of car )...
http://members.***.net/boondock/Carburetor/manifold.JPG
I'm interested in anything you guys can tell me!
Thanks for all the help! There is an inline fuel filter looks relatively New-ish... I get what your saying about the needles and grit, should have tried to clean it out abit when I was investigating the first time..DOH!. But Truth be told I'm really leanin' towards getting something either new or, based on what you guys are saying,already rebuilt. I guess I'm not really feeling like messing with someone elses jimmy-rigging. I have seen on Carburetion.com has rebuilt '70 4bbl (it says 4MC so I guess its a rochester?) for ~$250 could I use this for the $95 core or would it need to be a '70 to qualify? Or is that even a resonable price? Or maybe mine is not THAT BAD!???( in such an event I shudder to think what Bad truly looks like) LOL you guys rule!
PS my friend had also said something about the fuel mixture screws having no tension... mean anything to you?
Old Jan 31, 2008 | 03:17 AM
88 coupe's Avatar
Junior Member
Originally Posted by 70Wcars
........ And to your buddy who runs Holleys ........
10.44 @ 126.5 miles per hour with a Q-Jet.
Norm
Old Jan 31, 2008 | 05:04 AM
Barneyo's Avatar
In the Dec 07 JWO magazine (pg 25) under services offered, there
is a guy in Tacoma Wa who rebuilds '52 - '65 4bbl Rochesters. For
OCA members $200; and already rebuilt $225 plus $25 shipping.
Maybe if you wrote or called him he might do later years (?) or know
someone who does and or someone who does Q-jets....
Don Monroe, 8904 65th St West, Tacoma Wa 98467 (253)566-8488
Old Jan 31, 2008 | 09:48 AM
70WCars does carburetor rebuilds. He is the guy Oldsguy was thinking of.
Old Jan 31, 2008 | 12:56 PM
Coltonis's Avatar
Ok, Ok, so I will definately stick with a quadrajet! That leaves me with either rebuild kit for the one I got (ie doing things cheap) or getting one already rebuilt(ie. doing things right) I don't really see the point in sending my '78 to be rebuilt since it would cost nearly as much as a freshly rebuilt carb and won't '70-'73 q-jet give better performance than the '78 anyways?
88Coupe - LOL, you shouldn't show me pictures like that... I might start trying to get my car to do wheely's too!
Old Jan 31, 2008 | 08:23 PM
88 coupe's Avatar
Junior Member
Originally Posted by Coltonis
........ won't '70-'73 q-jet give better performance than the '78 anyways? ........
No.
Norm
Old Jan 31, 2008 | 08:51 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Some 1975 carbs are 800 Cfm if you can get a hold of one.
I'm willing to trade a brand new 4bbl Qjet for my 80 Delta 88
for an excellent running 2 barrel intake and carb.
I drive 100 miles a day round trip in my Olds and gas just keeps going up in price.
It was 89 cents a gallon when I started driving, and 9 years later it's $3.30
What a *****y time to be born.
Old Feb 5, 2008 | 03:22 PM
Barneyo's Avatar
Gee my heart bleeds.
When I started driving it was only .17 (thats seventeen cents) a gallon.
Let me start a thread with a way to extend your gas mileage...
Old Feb 10, 2008 | 06:50 AM
olds-cutlass's Avatar
Hi, do you all know what we here in Austria for one gallon regular fuel must pay?
just sit down; Euro €4.45 thats about $6.28 in us dollar, one Liter regular gas is around €1.17 and this is'nt the most expensiv if your car takes 98oktan it is around €1.30 liter x 3.8 = €4.94x1.41= $6.9654 a galon, wenn i have to gas up, 22 gallon is $138.16 on my BMW for 1 tank of gas, i must go to the bank and go for an credit! In some other European countries it is even up to €1.55/ $2.18 one yes 1 Liter, so you do have an better price, don't you? not an bad idia to start an thread with a way to exend your gas mileage! Berend
gtotony
Nov 8, 2022 11:47 AM
oddball
Oct 24, 2011 08:43 AM
yeahbuddy
Jun 1, 2010 05:38 AM
olds307owner
May 23, 2007 09:01 AM
ViceGuy
Mar 25, 2007 01:43 PM
