How rare is this ? 455 alloy intake manifold
Old Nov 15, 2007 | 01:13 PM
Aussie67Delta88Custom's Avatar
Hi All
I am picking up a 455 motor that is in pieces ... one of which is an alloy intake manifold that is a factory item.
ALL Olds bits here are rare, but are these manifolds common ?
thanks
Gary T
Old Nov 15, 2007 | 01:36 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
what intake manifold number is it??
you could look it up at www.442.com in the faq section
It would be pretty funny if it was from a 307.
Old Nov 15, 2007 | 03:18 PM
I don't think it could be a 307 intake. SBO intakes don't fit the BBO engines. I wonder what it could be...
Old Nov 15, 2007 | 03:29 PM
The only aluminum factory big block intakes are the 70-72 W-30 intakes. They will say either "OLDS W455" or "OLDSMOBILE W455", depending on the date of manufacture. This is located right on the forward runner. If real, these intakes sell for $500 - $1000. Note, however, that repros are now available and not worth as much.
Old Nov 15, 2007 | 06:52 PM
Wink not 307 ... it's over 20 years old
Joe,
The guy who owns it says he's had it for 20 years, so I doubt it is a repro.
When I know more I will let you all know.
Gary
Old Nov 15, 2007 | 08:36 PM
I hope that it is a W.
You never know when you get stuff in "pieces"
Old Nov 16, 2007 | 06:13 AM
Thumbs up It has Olds W455 on it !
Joe,
I picked up the motor and all the stuff with it tonight and the manifold had "Olds W455" on it ... and it's not in bad nick either.
J-chicago,
I'll list the number if it has one in the morning... too dark here now.
Pics will be put onto my Olds website over the next couple of days.
Gary T
Old Nov 16, 2007 | 02:27 PM
Oldsmaniac's Avatar
Nice score, you should check head casting letters if heads came with it. If there is a big F or H near the front or rear sparkplug hole you hit the jackpot!
Old Nov 16, 2007 | 04:40 PM
Cool 455 delivered !
Hello again ALL,
here's the pics of the motor bits including the W455 alloy intake manifold - http://groups.msn.com/MyAussie67Olds...or.msnw?Page=1
Oldsmaniac - I didn't get your reply until I got hoem from dropping everything off so I did not get a chance to check for letters on the heads, but one thing I do know ... there's no room for bigger valves !
*update ... I called the reco guys and they say they have "G" on them ... ? good thing ?
They are practically on top of each other.
Gary
Old Nov 17, 2007 | 01:58 PM
Oldsmaniac's Avatar
G heads are good and they have hardened seats for unleaded gas.....I believe they are 1971 455 heads, the F and H heads are W-30 heads and worth a few thousands of dollars!!
Old Nov 17, 2007 | 02:16 PM
Cool Doh ! ... W-30 heads would've been nice then :)
Oldsmaniac,
Ah ! ... they looked like they had hardened seats ... excellent !
Looks like this pick up could save me just as much as it cost ... even more .
could it have been fate ?
Just discussing it here has me itching to cruise
cheers from Down Under
Gary T
Old Nov 17, 2007 | 07:36 PM
SWEET
69442murph
Jun 7, 2014 04:57 AM
bainer1290
Apr 19, 2014 07:19 AM
REOLDS
May 5, 2012 07:52 PM
nonhog
Feb 19, 2010 01:27 PM
coldwar
Feb 2, 2010 07:06 AM
